anyone see the huge crash involving a honda civic
guy was on his green P's
coming down blair street. hit a tree and rolled
i happened to be on the verge of falling asleep in the car while mum was at the doctors
so all i heard was a massive BANG SHWOOOMM ERRRRRRR driver was okay
but f**k me was he lucky.. if he hit the tree just a little more sideways he would of been a goner fer sure
https://www.sau.com.au/forums/topic/238719-massive-crash-in-broady/
yerp alot
when we pushed the car back on its wheels he had this lost look on his face, like WTF HAPPENED?
jeez watta wake up call man.. about half an hour after that a guy in a VS comes flying past us
lol.. it was almost a pile up because i could of sworn i saw something red swish past in the rearview mirror.
i step out and theres a ute on the side of the road. cars stopped everywhere and a rolled over civic..
it had a fart cannon and 15 inch rims
must have stupidly hit vtec in the wet
massive crash > single vehicle accident
i guess its a "if you were there" type of thing
as much as i wanted to whip my phone out and snap some pics.
i thought that would be highly innapropriate to do it...
so i dialled 000
f**kin coolant and steering fluid everywhere..
(b1)
he was out cold when we had a look in the car..
i was a bit hesitant.. my cousin recently died in a car crash so i didnt know how ill take seeing a dead guy again.
his foot was still planted on the accelerator though so the thing was revving like f**k till we turned it off
front part of the driver side was crushed. door wouldnt open.
suspension, tire ripped out of place
the part where it curves for the window was on a 90 degree angle.
so from 45 degree to 90, thats pretty messed up
Cat? Do you mean car? Yeah saw the car, big bloody mess. But I think the reported speed of 150km/h may be a bit on the high side to be honest.
150 maybe high - cos its only an estimate, however, he was at a BAC level of 0.165 - so he doesnt know the speed, and says he saw a cat.
Being that drunk, you might as well see leprechauns dancing around the streets and in the inside of the car.....
Ahh... ...Leprechauns...
I always seem to have the worst luck when I see them... :(
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
