As stated we are fabricating custom oil pans to suit RB series engines. The pans can be baffled to suit your application.
The pans are extended 5mm lower but do not sit proud of the engine crossmember. They have wings extended on either side which hold an additional 1.5litres of engine oil. The pans also retain the factory windage tray. Standard sway bars etc still clear.
Pictured is a circuit style pan with pick up baffle to control oil surge under braking and also gates to control oil surge during cornering. The gates allow oil flow towards the pick-up but not away from it. The pans also can have a cylinder head oil return fitting fitted if required.
These pans are ideal for the modified street car or social track day enthusiast.
Pans are supplied on an exchange basis and take about 7-10 days to fabricate.
Cost is $500. Any enquiries please PM. Thanks Stuart.
$680 Fitted including 5 liters Repsol 10w40 synthetic engine oil & genuine filter.
MMm there are rather sexy.
Roughly how much to fit for us poor souls who dont have an engine crane?
(wink wink - deal for pan and fitment is what im getting at :()
sorry, not for GTR. There is enough sumps on the market for them already. sumps are hard to find for 20s & 25s and hi-energy want $950+gst for one. The basic one cost $400+gst and has no baffles in it.
hmm.... this could be good for me Stu??????
who did the welding tho????
Edited by BezerkR32
These are well engineered units that are designed to work with all of the usual mods that are made to Skylines
  • They allow you to still run a sway bar
  • They clear an aftermarket front chassis brace
  • They do not hang down below the front cross member so they are not the first thing to hit when you run over something (like ripple strips or just off the black top)
  • You can still run the stock front under tray
  • They include either a dash 8 or dash 10 fitting on the side of the sump to allow you to run the normal oil drain pipe from the back of the head down to the sump.
Here is a picture of one installed on the my son's RB25 engine in his R32. This thing looks so good that I may just have to get one for my R33 GTS-T. :thumbsup:
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
