Skyline Charity Cruise 2008
Rhinorebel
 Share
Hi all
Anyone going on the cruise coming from Tweed & Gold Coasts, there is a meeting point @ Maccas Nerang @ 8 am there we will be leaving around 815am to meet up with others @ Loganholme Hyperdome before 9 am and then on for the Aspley Hypermarket meet by 10am. So anyone coming to the meet @ Nerang i suggest don"t be late.
Cheers :) & :rofl:
  • Replies 317
what about people from the sunny coast? is there a group driving down to the meeting point as im not good with directions
+1 for sunny coast meeting point
Did you have anywhere in mind??
The most popular place where people meet if they have to head south or north from the Sunny Coast is at the Ettamogah Pub at Palmview and I usually allow about 1 hour for travelling. That way, you cover almost all bases - accidents, holdups, etc.
Edited by stubby131
Yeah im happy with either of those places. Ettamogah would be easy, already on the highway :)
I don't really head up that way a lot, once a fortnight or so. Was up there today tho actually. Love those RDO's :wacko:
I should hopefully have my air con fixed and new suspension by then too so my car wont feel like a barge! ;) what time are us sunny coasters looking at meeting up at the etamogah?
Hey all
I have done up a little flier that I will be putting on windshields of skylines I see around, and also one that can be put up in work lunchrooms if you want :) I just thought i'd put them in here incase someone else wanted to do the same.
Cheers, Anna :)
Handout___SCC_2008__2_per_page_.pdf Handout___SCC_2008__one_per_page_.pdf
I should hopefully have my air con fixed and new suspension by then too so my car wont feel like a barge! :) what time are us sunny coasters looking at meeting up at the etamogah?
Sunny Coasters should meet at the Etta about 8-8.15 & head off around 8.30.
That way you should get to Aspley around 9.30. You may get there earlier or maybe a bit later but at least you'll get there before it's time to leave.
Hey all
I have done up a little flier that I will be putting on windshields of skylines I see around, and also one that can be put up in work lunchrooms if you want :rofl: I just thought i'd put them in here incase someone else wanted to do the same.
Cheers, Anna :D
Hi Anna
Good thinking. I'll print some out & place them on vehicles that I come across down here on the Gold Coast.
Cheers :)
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
