Item:
R32 Skyline GTS-T
WRECKING complete minis- motor, box radiator, wheels, hubs and brakes.
so.. MOTOR, GEARBOX, WHEELS, HUBS, BRAKES NOT FOR SALE!
Bonnet -$150
Boot lid -$100
Doors -$200
Front Guards -$100 each
Front Bar (needs Repair) -$20
Tail lights (perfect condition) -$200 pair
Head light -$120
Front Seats -$250
Back seats -$150
Dash (with vents) -$250
dash Gage cluster -$100
Rear windscreen
already removed with tint -$300
Front windscreen -$300
side rear windows - $100 each (all windows will be removed if u want them)
Diff -$200
(Suspension not sure what it is offers!!)
some other stuff i can't think of at the moment.. ask if u need somthing else..
Brisbane- Rochedale.
Item Condition:
GOOD!
Reason for Selling:
Wrecking
Price and Payment Conditions:
as above
Extra Info:
Pictures:
ask and i can pm more to you
Contact Details:
CHRIS 0437 134 559 ANY TIME
https://www.sau.com.au/forums/topic/238780-wrecking-r32-skyline-gts-t/
hey mate
do u have the lil manual gear glove boot cover thing
im talkin about the plastic thing that goes around ur gear, the metal frame that holds the leather glove boot onto ur gear knob.
if so give me a txt with price please 0423594689
i just broke mine :)
ok if u need part cal or tx and i will call u cos i don't get on here much to check so don't think im ignoring you call on the fone pls... still heeps left manly panels and interior
this is going to sound funny haha,
do u have the fuel cap? does it still seal properly? As in does it make the Pfshhhh sound when u open it after driving to fill it up\?
PM me if you do
cheeers, David
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
