Item: R33/R34 GTR Brand New Reconditioned NPC Pull Clutch and Lightened Flywheel
Age: New
Condition: New
Price: $950
To Fit: (What car) R33/R34 GTR
Contact: PM or 0411 576601
Comments: Up for sale is my custom NPC single plate clutch and lightened flywheel fully reconditioned and unused. This cost me in excess of $1600+, NPC created this 600rwhp rated clutch for me with two main objectives in mind, driveability and performance. My wife had to drive the car so it needed to be streetable! The only reason I am upgrading to a twin is to contain larger horsepower requirements.
Edited by GO NUTS
i can vouch for npc clutches being easy to drive, i have had os giken clutches which are annoying to take off smoothly and the npc i have is absolutely awesome to drive around town, its not too heavy on the pedal but is running over 420kw at wheels without any issues, definately worth the dollars, good luck with the sale mate ;)
Edited by unique1
Appreciate your comments, thanks buddy!
Re the flywheel, is it a new item or is it the standard flywheel modified?
Any idea on postage insured to WA 6163?
PM sent R34kid!
how does it fit an r33?
theyve got different gearboxes...
Hi Bumblebee, I'm only quoting what my mechanic advised me. Apparently the pull clutch suits the R33 and R34 GTR
well they dont.. otherwise it would suit my r32 gearbox as well which is also a pull type box and exactly the same as the R33 one...
R34 = 6 speed getrag box...
the rest are completely different...
id fix it b4 someone makes a mistake in thinkin it will fit their car...
Edit: oh.. and get a new mechanic.. :(
Edited by Bumblebee
Different makes of gearbox yes but the same bell housing, same input shaft and same motor. Even the late, late GTR32's will fit this pull clutch. My mechanic is excellent thanks anyway
If it fits a r33 GTR then it will also fit a r34 gtt, goodluck with the sale.
    • That M3 looks like it handles so well, initial slight understeer on turn in followed by oversteer which is cancelled out as steering returns to centre. Looks like such a fun car to drive. In comparison the Skyline and Sierra look like they understeer more and thus need more heavier steering inputs...?
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
