Hey, i had a shop source a low km's rb26 a few months ago put new turbos on everything else.. thing is we have it tuned with the power fc dejetro low boost at 1.2bar and hi boost at 1.38bar, it was making 400hp at the rear's on 1.38 when i first got the car back iv done 2,5000km's in it i took it bak to the shop was going to wind the boost up a little more to make 420hp and on the powerrun it only made 375hp the mechanic said my mufflers blocked caus it is stuffed all the craps being shot out on boost and stuff and it makes a bit of a noise but i took the muffler off and it isnt blocked at all.. so that isnt the problem, i recently only changed coilpacks to spitfire d1's i doubt that was the problem but so i just put the nissan ones back in.. you cant really feel the power loss but its there and i think its gonna get lower if anything and i wanted to get 420hp, does this sound like i could be losing compression?. Thanks to anyone that has any ideas and can help.
https://www.sau.com.au/forums/topic/238788-losing-some-power-help/
You will know if you do a compression test.
Have you checked your catalytic converter?
There are many many many things that could be draining your power. It's foolish to make a guess without coming forward with all the details of what has been tested and other possible symptoms
could be fuel pump/filter/injectors/quality
could be a dirty air filter
could be a sensor
could be your ecu
after 2,5000km who knows and 375 to 400 isn't that big a difference, could be winter vs summer dyno, tyres, clutch, timing valve clearances and the list goes on
It would be good if it was the air temp i couldnt remember if it was walm or not when it was dynoed the first time. its got a new intank bosch044 fuelpump new injectors new ecu no afm's...hehe i thought about everything i dont see what it could be i know it isnt much hp but i dont wanna have to add more boost to get it back to what it was making you know.. i want to get to 420hp
That fuel pump isn't in tank. And if you have the intank model then it is likely to be an 040 which won't see you all the way to 420hp anyway.
Also check for small boost leaks using an isolation pressure charge system
Hey mate, Its an intank 044 i know for a fact.. there an external and internal model 044.. Ok ill have a look at all the lines for leaks have actually had a problem with a leak before seemed to make the car run like shit but seems to run fine i get knock pretty hi but its ment to have been tuned for around 20 on the fc controller on knock but it goes up to 30-35 so i thought thats slowly killing my engine and the pistons are starting to get f*ked and shagging the engine??.
I spent 25grand on this engine i know 30hp isnt much it just shouldnt be happening and i wanna find out whats doing it..
There is no in tank 044. There is an 040 which is an in tank pump but it flows much less. You can use the 044 and mount it in tank but it is not an in tank pump as such.
Knock of 35 is not bad. I would start to be concerned after 40 or so but anything around 35 will be fine.
25k on an engine? What the hell did they put in there? I can build a whole car with a 800hp engine including suspension and brakes for ~ $25k. That figure can't be right
ZOMG! I lost 25HP between dyno runs!!!
Shit... Never seen that before... Oh wait... Yes I have... It's just the dyno not correcting it out perfectly. You haven't lost power, move on with it. Chasing dyno numbers is pointless. If you want your magical missing power back, when you do the run, make the air temp sensor on the dyno read higher then it really is...
25k... is that including the turbos, and every single part?
cause my forged build cost me 7k (excluding turbos etc etc), if you take all that into account, its 15k
"800hp engine including suspension and brakes"
I dont think your building an 800hp engine for 15k :>
on topic, what about your spark plugs ? Checked them out ? 25hp is a fairly small loss of power.. its possible the dyno is due for a calibration.. or like someone said, the air temp was ~5+ degrees higher.. aging/fouled plugs could also lose some hp.. lots of little things..
Wow got a few quick replys then lol, well all up after bein in and out the shop a year it was 24grand it was for everything turbos computer injectors rail reg power pc cams - gears springs, twinplate clutch, gearbox engine mounts just about everything except crackin the engine open,i will do that when i get enough money and want the car off the road again, If 35knock isnt that bad then i guess thats sweet pretty happy i thought that was bad.. im not after a jagic number on the dyno either if i wanted that i would of got a t78 or something i want atleast 400 caus my mech wont up the boost till i get that problem sorted out he thinks its my muffler and it isnt.. i thought it might be the coil packs thats why i was saying i changed them just after i got told it was 30hp less on the spitfire manual they show a dyno graph of gaining 30hp on a rb26 over the standard nissan ones.. the sparkplugs were changed when the engine was put it..fuel filter ect, i was told the 044 pump in it is in tank and i can hear it at the very bak of the car under the tank?, cheers
oh you were referring to OP not dan.. I thought you were claiming dan's figure of $25k was too high for an 800hp car...
spitfires are a slight improvement over standard coils.. if your standard coils are old and breaking down under load, then splitfires will make a big difference.. but in any circumstance, they shouldnt lose you HP..
In the end, like we've suggested, its likely to be something else (dyno calibration, air temp) rather than your actual car... If your tuner is convinced its the cat, drop the exhaust off on the dyno and see if that makes a massive difference.
nah i was talking about 25k for that dude to make his setup... seems a bit high as he also said he had to source a low km RB26 (which brings other questions)
25k... with a low km RB26... was that a stocker or a build 26 with low kms?
The 25k was including the motor i think i payed about 6grand for that its just got standard internals i was told it should last a while enough for me to be saving to do a rebuild but i dont see that happening for a while the engines holding up fine so far no noises or anything i just wanted to up the boost a tad more then leave it..
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
