Hi,
I just tried putting on alloy pineapples in my rear cradle but i couldnt get my breaker bar with the socket on the nut to undo it. The reason being the steering arms from the hicas pass directly in front of the nut and there isnt enough room to get the breaker bar/ratchet with the socket. I tried undoing it with a spanner but the spanner was flexing so much it was on the verge of snapping.
I have a hicas elimination bar on the car. Can i unbolt the bar so the arms drop lower and try to get it in there.
Will my rear suspension become un-alined because i have removed it.
How have other guys put these in their cars?
Thanks
https://www.sau.com.au/forums/topic/238806-fitting-in-alloy-pineapples/
I had to take the steering arm off mine, and use a long (maybe 500mm) breaker bar. If you just pop the tie rod end out then there will be no difference to the alignment when it goes back in.
ok.. ill try removing the tierod end later on today.. i didnt really want to remove the hicas elimination bar as the holes are elongated which will definately mean it would need to get re-aligned.
Any other methods/suggestions?
Thanks for the quick replies
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
