My headlights aren't symmetrical. One of them doesnt sit flush with the bonnet. It's kind of too forward, and there is a massive gap. It's even more noticeable now after installation of the eyelids.
Any way to adjust them? Is it caused by a poor job of installing the front bar from previous owner?
Thanks
- Ang
first make sure its the lights not the bonnet, the bonnet is easy to move up or down you just twist the rubbers in or out.
if its the lights, hopefully there is a bolt missing or loose somewhere, else your car may be a lil bent
Yeah I don't like the sound of it being bent...
And nothings loose in the light housing as well
Umm, I was told by a mate ages ago when I got the car that it's probably the bonnet.. But the two rubbers towards the front seem to have given up the ghost.. So I don't know if it's possible to adjust them at the state they are in.. I'll need to try and dedicate a few hours of finding out the culprit.
You can order new bonnet rubbers from any Nissan dealer. New ones for my R34 were $7.50 each.
I've uploaded 2 pictures. One of the top of my left headlight, and one of the top of my right. Now I noticed something tonight, can anyone else confirm this for me?....
Notice how the glass/plastic is clipped onto the black part and where they meet is nice and flush?
And notice on this one how there is no clips and it's sorta seperated?
very unusual.. I tried pushing them back together but it hardly budges.....
so it looks like the lense has been removed form the housing at some stage and wasn't put back together right and is missing the metal clamp. solution either get another headlight or take it apart and reseal it again trying to find a replacement metal clamp...
Do you think there would be enough movement to make the headlight flush again? Attached is a picture of the front of the car, notice the gap on the left, and the lack of on the right
im an apprentice panel beater and from the pics i can tell ur whole headlight is low as there is a noticeable sized gap where the headlight meets the guard. in saying that adjusting the bonnet lower with the rubber stops will only fix the gap at the bonnet wont really solve the problem
you could either try loosening all the headlight bolts should be some behind the front bar as well and try push the headlight up and tighten the bolts up. if that dosnt work it means ur headlight panel which is welded to the upper radiator support is low which would probs just need a tap up with a sledge and a block of wood
I had a bit more of an inspection today, and it seems like the seperation I showed earlier is the cause of the majority of the gap. Where the corner of the light meets the guard shows quite a gap. If I can somehow take the headlight off and remove the lens from the housing, and reseal it, that should reduce the gap drastically.. Now to take the headlight off.... Looks a bit mind boggling
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
