Hey guys,
well I have done a decent amount of mods to the engine, brakes and soon suspension wise... now I am thinking about getting some nice new body panels... but I have a few questions, in particular about bonnets at the moment because I have a few stone chips on my current one.
1. are fiberglass panels illegal?in particular bonnets? ;)
2. I know people say they are lighter and you can go faster etc... but I want an honest answer.. would the weight of replacing a metal panel with a CF/fibreglass panel be a large difference or is a couple kg negligible?
3. I would assume it gets sprayed the same as every other panel in 2pac paint etc... but would a fiberglass bonnet's paint chip/warp due to engine/turbo heat?or do you have to attach the blanket thing to the bottom of it or something else?
finally guess I am asking.... do both an aftermarket and standard bonnet function identically? or is one a better option for stuff like strength, weight, warping paint...etc?
if it makes a diff... my car is a street car... only been to the track once...probably not for a few years again...
Thanks,
Adam :)
https://www.sau.com.au/forums/topic/238813-fibreglass-bonnets/
Check out HPI mag. There's a QLD company that makes ADR approved (read legal!!) fibreglass bonnets. Lighter than steel ones and keep things cooler with the venting.
It's a looks thing, functional, less weight and legal. 2 pac painted would blend in sweet.
You're on the right track with temps.
If you run a high mount turbo that's the only time you might want to look at say a turbo blanket to cover the turbine housing, to protect the bonnet etc.
Hope I'm not babbling on. Good night and good luck with your choice ;) .
Thanks for the advice felas,
dw, turbo is low mounted... had that much trouble getting it in tho I almost went highmount...
ok... so it may be a better option repairing the stock one by the sounds of it... just for strength and legality reasons... will post up more questions in the morn after they pop into my head overnight ;)
cheers guys.
99% of fibreglass bonnets are defectable/illegal
stock = stronger
FG = lighter and vented
neither will warp in teh heat if made correctly. weight you wont really feel any difference.
ever lifted a r32 gtst bonnet, that thing probably made of cast iron ;)
It's funny watching the gtr owners struggle with it due to being used to their fancy aluminum bonnets :)
ever lifted a r32 gtst bonnet, that thing probably made of cast iron :merli:
It's funny watching the gtr owners struggle with it due to being used to their fancy aluminum bonnets :D
hahhaha ofcourse you feel it when you open it, there is a major difference in the gtst V GTR bonnt
but not worth much when driving
I would really like to know where you got your figures from? I don't mean to be rude, however you might be surprised once you approach your state authorities and seek clarification. As my understanding is that the bonnet itself only plays a small role in crumple zone testing.
i pulled the figure out of the air,, simply since in NSW "any modification that would affect these crashworthiness safety standards should only be made on the advise of the vehicles original manufacturer or an engineering signatory"
so unless you get it engineered - it is illegal.
I'm in talks with several state transport authorities, at the moment trying to seek explicit clarification on these rulings, and so far they have been somewhat helpful. At this stage I'm not going to rule out all fibreglass/carbon bonnets to be illegal. Hopefully will have more on this soon, along with supporting documentation :(
  • 4 weeks later...
Not worth much if done on it's own but for someone that is watching their weight, a steady step in the right direction. Lightening a vehicles weight would have to be the most affective mod you can carry out.
  • 2 years later...
whoa... 2008 called.. ;)
yeah blits bodykits do an "ADR approved" bonnet.. But my understanding from some talk is that it is QLD Transport approved.. So just check with any local authorites/state transport to ensure.. Although i'm sure most won't even know the rules and will get a different answer to everyone you speak to.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
