  • Replies 52
http://www.skylinesaustralia.com/forums/JJ...B2-t204414.html
justjap are forum sponsors
$199 + delivery for the same item
win win ftw?
Yeah i saw that one, but a few members like bubba have mentioned that they arent so good. Ive also had bad experience with a JJR intercooler, which need a lot of modifications to fit onto the r33.
Lucky i had a welder and other tools etc to modify the intercooler, otherwise i would of been up a creek with no paddle.
So i learnt my lesson in that one.. pay a bit extra for a branded product, that will just bolt up with no modification.
But thanks for the heads up on that one. Appreciate it alot.
Have heard of lost of issues with the JJR split dump/fronts though.
i meant that u heard it :P
And i wouldnt b surpirsed either, the JJR stealth intercooler was shocking. Hardly a direct bolt on.
I'll b ordering in the exhaust system very soon...
then clutch/flywheel and fuel pump.
and finally tune and more Boost!!
are you sure the clutch is standard? You never know sometimes what the previous owners have put in.
Alternatively are you sure your running 270hp, cause there is no way that would hold up for long.
I bought my car from a dealer and he assured me it only came with the exhaust and pod, but I've since then modified it with basic things. I've only travelled 5000km with the tune and havent had any signs of my clutch slipping yet.
I would check it, but I dont know how/where to look.
mmm the standard clutch is pretty strong i must say.....i still had the NA clutch in when my motor was transplanted and held fine the mechanic said its on its last legs and i was still doing launches etc and it still held fine for over 1.5 years? lol daniel just drop ur box out :/ and you'll see if its AM or not ;) hahah
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
