we used a rb25 turbo on an rb20 and it was making 271rwhp on 17psi
so there is nothing wrong with using a 25 turbo iether just personal preferance and budget..
Rb20
VG30
FMIC
Fuel Pump
Exhaust
198rwkw @ 15psi
Did 1 run on 17psi and was going past 208rwkw when it ran out of fuel and was backed off, probably didnt have much more than 210rwkw.
Rb20
VG30
FMIC
Fuel Pump
Exhaust
198rwkw @ 15psi
hey bro, thanks for the power figures :O.. will upload mine once i do my tune soon
niran, where are you looking to get your tune done in the perth area?
i am also looking into the VG30 turbo setup..
(sorry about posting 3 times, comp messed up :P)
Edited by fourdoorlove
(sorry about posting 3 times, comp messed up :) )
Hey bro
Yep i am going to be getting it tuned in perth.. i just got a yellow sticker so just been busy trying to get that off.. but after that the plan is to buy some r32 gtr injectors, and then give it to all star garage and get them to install a nistune chip and then get them to tune it.
Thanks niran
guys i need some info asap how do you tell the difference in the
Ballbearing vg30 t3 turbo
and the
Jurnal bearing vg30 t3 turbo
need info a.s.a.p?????????????????????????????????????????????
Hey man
I think it goes by the versions.. There was another thread where i asked the same question as you did and its somewhere on skyaus most likely on forced induction.. Besides that if you already have the turbo you could go to a jap shop and ask them too
niran
  • 4 weeks later...
  • 1 year later...
i recently got a vg30 turbo to bolt onto my rb20, i have a few questions though, how do i find out if its ceramic or steele? it sais 45v2 on it.
Also, im putting the rb20 actuator on the vg30 turbs, will it hold 15psi or will i need an external wastegate?
  • 4 weeks later...
how are u guys runing 17 psi through the vg 30 turbo if it has a ceramic exhaust wheel. is there a ball bering version with a steel exhaust wheel? and what are u doing ecu wise to run 17 psi remap? or just a tune?
niran i got
FMIC
exhaust
040 FP
Ebc
i want 198rwkw
what do i have to do apart from bolt the turbo on? coz that bit is no prob
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
    • Does any of you guys have instagram pages for your builds? Keen to see some Aussie builds. I still can't figure out how to post photos in here.
    • That awesome thanks for that.
    • You can Remote any of these VR30..globally  Check: AMS Performance | Racebox | Sonic Tune | Soho | Z Motorsports | Specialty Z    Performance Parts | AMS | Z Motorsports | Boosted 6 |    Exhaust | Fast Intentions | ARK | MBRP Motordyne | Borla    There is someone in Sydney with 650whp   I am at 430whp without flex fuel, but FBO & Flex-fuel will push you to 500whp!!
