Hey guys, just thought i would post some pictures of my new car for you to see. It is a 1995 s1.5 R33 Gts-t. Let me know what you think.
Bit of Background:I bought the car for $5500 two days ago. It is unregistered and there are a few things I need to do to it before it passes pits (New GTR Bumper, Sort out radiator issues and idle problems). It is stock apart from the inter cooler and boost gauge and spoiler (and the r34 engine transplant). Taken it for a drive though and I can not believe a stockish car can pull so hard!!! Anyway here are the pics..hope u like.
Will
ps. I am selling the rims. They are apparently the wrong offset for R33 (previous owner put them on). If anyone knows how to identify the offset could they let me know. Thanks.
https://www.sau.com.au/forums/topic/238868-my-new-car-needs-work-tho/
  • Replies 56
Yeah i felt i got a fairly good deal :merli: I do drive a hard bargain lol. Yeah i already checked that the car can be registered. Basically i got it through a friend of a friend who was too lazy to sell it. It had been sitting outside his house for 8 months cos he lost his license and then he let it fall out of rego so it became hard to sell. There are a few problems with it though. The idle is the main problem. The engine conversion looks like its been done in someones back yard. The idle control valve isnt even plugged in and i took it apart the other day and the solenoid was rusty. Basically you cant let the car drop below 1500 rpm or it will stall. Doesn't make for great fuel economy lol.
btw thanks Mr Fanny for that info on the wheel offset. Ill go and check it now. The problem is the wheels do scrape at hard lock. Its such a shame because i think they suit the car perfectly. Anyway hopefully i will be able to find something similar to fit properly.
Here is a pic of the engine bay. Will hopefully be putting a powerfc into it soon to get rid of the idle problem. They used all the r33 wiring and computer with the r34 engine so hopefully a full ecu replacement will fix the issues. Got to book it in at Hyperdrive.
Edited by SeRiUs
Dude an R33 with a neo conversion for 5.5. Tell me where you buy these things, ill take two! I see the traction control has been done away with. Good idea!
Haha. As I said it was a lucky buy and the seller was lazy, just wanted the cash.
Seriously, that's a great buy!
How many Kms?
Existing wheels actually suit it!
166000Kms Yeah i think the wheels look great but they scrape when i turn hard right. guys at the pits would pick up on that fairly quickly i think and it would drive me mad. If you know anyone selling similar rims to suit a skyline i would be interested.
Hey guys this probably isnt the right place to post questions but do you think wheel spacers would solve my offset problems? There is someone selling a set of 15mm ones here : http://www.skylinesaustralia.com/forums/br...66#entry4175366
Thanks in advance
Will
Dude thats a f**king steal. My friend bought that car about a year ago for 13k.....then he sold it to some clueless asian bloke apparently which I assume is the person u bought it from? Apparently he almost burned the clutch and drained the battery trying to get out of my mates driveway haha.
But nah that car is (or was) f**king clean and the engine is good just needs the shit around it fixed like the idle control
That is so funny you said that. The clutch is brand new cos it was burned out and i had to buy a new battery cos the other one wouldnt even turn the radio on. If you know anything about the engine conversion could you let me know? I am trying to find out as much as I can. Also did your friend look into fixing the idle problem? I was hoping he had found how to fix it but never got round to it :)
Also did your mate have problems with the heater cos I found it was disconnected. I went and bought new hoses and have plumbed it all back up but it seems to go hot and then cold. I am hoping its an air lock in there so i dont need to replace the whole heater core!
Edited by SeRiUs
That is so funny you said that. The clutch is brand new cos it was burned out and i had to buy a new battery cos the other one wouldnt even turn the radio on. If you know anything about the engine conversion could you let me know? I am trying to find out as much as I can. Also did your friend look into fixing the idle problem? I was hoping he had found how to fix it but never got round to it :P
EVEN MORE INTERESTING THREAD NOW...
That means that after you fix a few things up, the car will be worth >DOUBLE!! :) Tez
Fixed the heater problem!!! Perfect hot air all the time now and no more bubbles from the radiator lol. Thanks to raps86 for all his help! And yes. hopefully when i seill it in a year or two i will get my money back lol. wouldnt that be a dream.
Im not too sure what it is scraping, it isnt the side panels tho. The car is too low to see under it. Anyone know of a way i could check this in my backyard? Maybe put it up on two jacks and test the steering like that? I would be a bit worried at how stable that would be tho.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
