A JDM GT-R is looking alot more attractive given the probable waiting times for an Aus spec delivery. However my only concerns (as comparatively minor as they may be in comparison to the performance of the car) are in regard to the multifunction display and the switchgear.
I cannot speak or read japanese and so I have concerns about how useable the multfunction display will be. Is it realistic to think that with the arrival of ukspec cars (which i assume will be delivered long before aus spec ones), that english versions of the japanese switchgear as well as a fully english program for the MFD will become available? Is it also possible to get the gps working with map content from australia or is the only solution to wait untill the end of 09-10 for the data to become available in aus-spec cars and then attempt to get hold of it (obviously taking into account nissan australias refusal to have anything to do with JDM cars.)
https://www.sau.com.au/forums/topic/238881-jdm-switchgear-and-mfd/
its quite easy to navigate the MFD and other controls even without any japanese language skills. and some kind folk have done up neat little translation manuals with functions translated and how to get to them. they have done up translations for the controls to.
JDM is still a good option as I think nissans delivery times will still be quite a way off, and with limited supply you could be waiting until deep into next year.
It would be a costly exercise but it could be done. No sat nav though Aus spec cars wont get this for a while. Though you could integrate any sat nav that had composite video out.
Parts alone would be over $5k then there'd be a bit of stuffing around.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
