Hey
I went to the mechanic the other day and he said the turbo was leaking, something to do with the manifold. The effect of this was that i was losing power and boost, and u can hear air coming out instead of in from the engine bay. He quoted me $380 and i have to leave the car overnight, is this a decent price or am i gettiing ripped.
Any help appreciated..
thanks
will
https://www.sau.com.au/forums/topic/23889-turbo-leaking-losing-power/
i had a leaking problem too about 6months ago. mine was making a screaming sort of sound at full boost and was losing power.. mine was from where the turbo bolts on and all i had to do was tighten up the bolts half a turn each and only took 10mins... might be worth checking that first b4 you pay that sorta money for something that might be this simple
sounds like a good idea....just one question, im not much of a mechanic...how did u get down there to tighten the bolts, which bolts? like do i have to take out anything before hand .... Cause i know the turbo is low mounted, but don't really know how to get access to it....
umm im no mechanic either so this might not help you much.. but i remember taking the heat shield off and there was little metal clips covering 1 side of the bolt so they couldnt turn.. so after bending the clips back i just tried to turn the (not %100 sure how many) 4ish bolts tighter b4 bending the clips back over so they dont turn back at a later stage... i left my heat shield off which im not sure was a smart idea.. but it made putting the dump pipe on a bit easier.
What happened was that i lent my car to someone, who cracked the front bar, not sure how it happened, but the mechanic said that may be the cause for the problem in the manifold... not exactly sure of the seriousness of the problem atm ... but will check it out next week...
Jetdat - hopefully it is...save a bit of money, lolz
thanks for all the replies
btw...anyone in Sydney know of a good mechanic to go to to have it checked out, i've been to fussys and got quouted 380...but he did not explain seriousness of the problem, but just saying that he needs to have the car overnight...
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
