Item:
WORK Emotion XD9 18 x 10 + 18 in white
4 - 6 weeks
Condition:
Perfect
Price:
$2,500
To Fit: (What car)
Anything 5 x 114.4
South eastern suburbs, Melbourne
Contact:
PM or call/SMS 0416 623 381
Comments:
WORK Emotion XD9 wheels in 18 x 10 + 18 offset in white
Perfect condition, only been on the car for about 4 - 6 weeks, no marks on them and in as new condition. Bought them brand new from Japan, directly from WORK so there genuine WORK Emotion rims
Has the glow in the dark Emotion stickers on them
Front tyres are TOYO 235/40/R18 which have only done about 1,000 km as I bought them new, rear tyres are also 235/40/R18 and are LINLONG brand, still have 40 - 60% tread and well and truly roadworthy
Thanks
https://www.sau.com.au/forums/topic/238977-work-emotion-xd9-white-near-new/
Sorry man, 19s too big
Would be keen on a swap for a set of 18's with heaps of dish and minimum 10" wide, looking for something with a negative offset
18 x 10 - 5 or something similar would be ideal :D
thats cheap..... if they were 9's on front they would be mine :P
Yep, there very cheap especially because they come with tyres and the rims are practically brand new
They are a little big to run on a GTST but from what I have seen with R32 GTR fitment, these wheels would be PERFECT on a R32 GTR. They sit nicely on my R33 GTR but will sit out that little bit more on an R32 GTR as the guards are smaller
Comes with tyres guys, front are almost brand new and no camber wear, rears are around 60 - 70% and plenty of tread left still
Thanks
10inch wide is pretty fat! Would there be any scrubbing on a 32R?
Yep they are nice and fat :dry:
Well they fit really easily on my R33 GTR with no rubbing at all, R32R guards are only a little bit smaller and from what I have seen they will sit very well. Really flush with the guards and the tyres will tuck under perfect so wouldn't expect any rubbing
If anyone else knows, please feel free post up
Just wanted to add for an 18 x 10" rim its pretty damn light so would be suitable for track work as well
Thanks
Yep they are nice and fat :kiss:
Thanks
I have just picked some of these up smae specs and have fitted to my R32 GTR. I am running a fair bit of neg camber which helps.
Tuff Offset on R32 GTR ;)
  • 3 weeks later...
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
