I know of QNX, but I don't think I could be much help to you (I have zero experience with it).
If anything, I imagine you could do a possible create an image of the HD using something like dd, and work with it that way:
http://en.wikipedia.org/wiki/Dd_(Unix)
https://www.sau.com.au/forums/topic/238982-anyone-know-qnx/#findComment-4176904
any reason why Nortons Ghost can't fill the task? or even windows backup?
I really depends on what the file system is and whether Ghost supports it.
A quick google brings up this:
http://quics.qnx.com/cgi-bin/dir_find.cgi?.../os/utils/disk/
and this in particular:
http://quics.qnx.com/cgi-bin/print_des.cgi...X_drive_copy.gz
It will require a bit of unix knowledge to understand and get running, but it's a beginning.
https://www.sau.com.au/forums/topic/238982-anyone-know-qnx/#findComment-4177604
the system that this thing is in runs QNX and everything that is attached runs on top of it.
what I need to do is pull this thing - unlock it , dump it and play. I'm working on an alternate image to load back into it on another drive exaclty the same. issue being there WILL be a software difference between the two images. its that difference that I need to compile into a third image so I can test my theory.
ben,
was looking at hd tools to start fiddling with it but considering I only have one copy to start with I'd prefer that someone else imaged this thing. if I lose the data I am literally screwed!
https://www.sau.com.au/forums/topic/238982-anyone-know-qnx/#findComment-4177809
ben,
if an image is all you want to literally duplicate the data, master boot records and all the other information there are a few tools that will duplicate the disk without any risk to the existing disk.
1. Norton Ghost - use a commercial dos based version. Version 7 springs to mind. (My Pick)
2. HDClone 3.2 - need an exact duplicate of the HDD for this one. Or at least last time i used it it wouldn't create an ISO or image, but it was free and did the job quite well.
3. Acronis True Disk Image.
I have used all three and all three have their quirks but can do the job of just duplicating the data so that someone else can have a fiddle. I used all three to image ATM Hard drives in the past quite successfully and Norton if by far my favorite.
I can probably hook you up with a Norton Ghost image, what format is the HDD 2.5, 3.5, SATA, PATA, SATA with a connector like you see on HP and some Compaq's? Need more details.
If no-one else will help you I can pop over with my ATM toolkit and laptop and give it a go. We won't frack the HDD the worst that might happen is that the drive is encrypted and you will need some more serious tools.
You got my number if you need me. I can't help yopu with the code but an image should be all too easy.
Edited by Data Queue
https://www.sau.com.au/forums/topic/238982-anyone-know-qnx/#findComment-4177938
ben,
That's a fair call. I know the principle behind what you need to do, but without actual experience I'm really not willing to put my hand up and say I'll do it considering the nature of it all (And I probably don't have the set up to do it either). I would have a call around a few of the data recovery places to see what they can do. The principle is the same.
Once you get an 1:1 image (especially if created using the unix dd program) you can then mount (load) the image up (in linux or similar) and use it as you would a normal drive rather than using the original, burn images to CD's et al.
Recently one of the hardware guys at work needed to do some data recovery and used these guys http://www.datarecoverylabs.com.au/ (they're local in brisbane) and I believe he said they charged $99/h. Which is damn cheap. If it's worth paying that, I'd be giving them a call, as I can't see why they couldn't do what you needed. They'd also provide a much better guarantee.
I'm not familar with ghost or acronis (beyond knowing they're both good at what they do). Because it's QNX, it's most likely running on QNX's proprietary file system (e.g. Not something either Windows or Linux* typically supports). I can foresee that being an issue with both of the above software, unless they're capable of doing a blind 1:1 copy.
* Though I know you can add support for this FS in linux.
https://www.sau.com.au/forums/topic/238982-anyone-know-qnx/#findComment-4177947
Good point.
https://www.sau.com.au/forums/topic/238982-anyone-know-qnx/#findComment-4177959
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
