  • Replies 76
gettin the brakes fixed ey? LoLz
"would you happen to have a bukit or a huse bru?....i needa git wit asip"
Hopefully going to get the brakes done and talk about a little something hahaha :O
and what was that last part i have no idea what u sed bruh haha...
Ive updated the first post for people that might not read the whole thread
Sif Ash is down. He's not a true westie!!
I'm a maybe depending on work.
Wouldn't mind coming down to say hi
AS IF your going to rock-up. I know "end of month" will get in the way ye... or is it "i dont wanna put wear on my tyres" this time? :O
Im as WESTIE as it gets.
Ethnics these days, think they own the west... sheeesh :)
thanks man.
and ross you haven't seen beached whale on youtube yet? if not i suggest you watch it now and tell me how funny you reckon it is tomorow :O
AS IF your going to rock-up. I know "end of month" will get in the way ye... or is it "i dont wanna put wear on my tyres" this time? :happy:
Got my street tyres on it now so you can GAGF :blush:
But yeah month end is busy today so I'm still a maybe :banana:
i finish work at 7. il come depending on what time you guys will be there til
should be there for around 2 hours or less?
damn alot more people coming tonight then i though...hopefully the carwash is empty lolz.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
