Hey Guys,
About 6 months ago I purchased a fully rebuilt T25G for a turbo conversion from Lavish Performance (who I cant get in touch with anymore :) ) Ever since i have bought it, i have kept it wrapped in a plastic bag (sitting upright on the exhaust housing studs) in my room away from all dust and moisture... Yesterday i took it out and noticed clean/clear oil on the rear impeller wheel and few drips of oil...
Q. Is this normal? Could this be due to the bearings been lubricated when rebuilt?
Regards,
Sarkis
You always lubricate a turbochargers bearings (in the center section) when assembling it - means there's some lube at start up and helps prevent corrosion if it sits around for a while .
Most turbochargers have literally a piston ring on the turbine shafts hub just inboard of the turbine wheel itself . If you stand a turbocharger on its turbine end oil can weep through the small gap in the piston ring and run around the back of the turbine wheel and drip out the outlet . It's just gravity doing it's job .
If you had the turbo horizontal it would probably do the same thing out the oil drain hole in the bearing housing . When rebuilt turbos usually have plastic caps fitted to the oil inlet and drain holes to keep dirt and dust out .
Provided the people who rebuilt it did the job properly you should not have any issues , I'd probably put a couple of drips of clean engine oil down the oil inlet (emphasize just a couple of drops) just before start up just so it has a little before oil pressure is up .
If really paranoid you can start it up with the oil drain pipe or hose removed from underneath and observe oil running out of the drain hole temporarily - have a drain pan or tin handy to prevent spills .
Getting a little OT , often its price neutral to buy new cartridge (center housing and wheels) with bush bearing turbos . That way you get all the important bits brand new
Cheers A .
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
