Hey Guys,
About 6 months ago I purchased a fully rebuilt T25G for a turbo conversion from Lavish Performance (who I cant get in touch with anymore :) ) Ever since i have bought it, i have kept it wrapped in a plastic bag (sitting upright on the exhaust housing studs) in my room away from all dust and moisture... Yesterday i took it out and noticed clean/clear oil on the rear impeller wheel and few drips of oil...
Q. Is this normal? Could this be due to the bearings been lubricated when rebuilt?
Regards,
Sarkis
You always lubricate a turbochargers bearings (in the center section) when assembling it - means there's some lube at start up and helps prevent corrosion if it sits around for a while .
Most turbochargers have literally a piston ring on the turbine shafts hub just inboard of the turbine wheel itself . If you stand a turbocharger on its turbine end oil can weep through the small gap in the piston ring and run around the back of the turbine wheel and drip out the outlet . It's just gravity doing it's job .
If you had the turbo horizontal it would probably do the same thing out the oil drain hole in the bearing housing . When rebuilt turbos usually have plastic caps fitted to the oil inlet and drain holes to keep dirt and dust out .
Provided the people who rebuilt it did the job properly you should not have any issues , I'd probably put a couple of drips of clean engine oil down the oil inlet (emphasize just a couple of drops) just before start up just so it has a little before oil pressure is up .
If really paranoid you can start it up with the oil drain pipe or hose removed from underneath and observe oil running out of the drain hole temporarily - have a drain pan or tin handy to prevent spills .
Getting a little OT , often its price neutral to buy new cartridge (center housing and wheels) with bush bearing turbos . That way you get all the important bits brand new
Cheers A .
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
