hey folks, ok basicly my car is stalling while im moving, an it tends to be in 5th gear and when im clutching in, thats when this has happend, luckily ive been driving in a straight line because the steering goes when this happens so ive been lucky so far but i need to get it fixed asap, anyone know why and how to fix this?
note i recently installed a pod and put new oil in the gearbox, theres another thread on here regarding the oil i put in but no one has answered and i realy need this solved, basicly in regards to the oil i put in 3 litres according to the help from autobarn, and that worries me alone.
Anyone know whats going on and how to fix this?
cheers
https://www.sau.com.au/forums/topic/239094-car-stalling-need-help/
cheers
Ok thats really weird cause my car just started to do that, out of the blue really but has happened only twice will post if anything knew happens otherwise will be following this thread closley
i forgot to mention it sputters while cruising, like vvvvvv.vvvv.vvvvvvvvv.vv every now and then. also, i was testing it a bit and it only stalls when i hold the clutch in to long when changing gears. the revvs just drop like a rock, so i goto keep blipping the velocitator to keep it from stalling, any difference in story?
cheers
Mine is stalling a little often at the moment too... ...but when I go from 1st to Neutral... ...and mostly while turning while doing that... ...eg three point turns...
But it's been a while since I got it serviced (damn cash flow)... ...So I think it will be picked up in my next service...
its the afm 100% you probably havent clamped the pod on properly. Ages ago id taken the lid off my airbox to get that gay woosh sound and for about a day the car would stall like urs too until the computer kind of worked out what the hell was going on and it went away. If the car wasnt doing it prior to the pod being installed then chances are its something to do with that.
good luck!
cheers mate, i think your right, i had a glance last night, and i might have found some spots, i really thought it was the computer cracking the shits, but still hasnt worked out the right amount of fuel/air ratio. awell, will pull apart and start again lol.
oh P.S is there a way to reduce the WHOOSH sound the pod makes? it sounds a bit wankish lol
PEACE
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
