hey folks, ok basicly my car is stalling while im moving, an it tends to be in 5th gear and when im clutching in, thats when this has happend, luckily ive been driving in a straight line because the steering goes when this happens so ive been lucky so far but i need to get it fixed asap, anyone know why and how to fix this?
note i recently installed a pod and put new oil in the gearbox, theres another thread on here regarding the oil i put in but no one has answered and i realy need this solved, basicly in regards to the oil i put in 3 litres according to the help from autobarn, and that worries me alone.
Anyone know whats going on and how to fix this?
cheers
https://www.sau.com.au/forums/topic/239094-car-stalling-need-help/
cheers
Ok thats really weird cause my car just started to do that, out of the blue really but has happened only twice will post if anything knew happens otherwise will be following this thread closley
i forgot to mention it sputters while cruising, like vvvvvv.vvvv.vvvvvvvvv.vv every now and then. also, i was testing it a bit and it only stalls when i hold the clutch in to long when changing gears. the revvs just drop like a rock, so i goto keep blipping the velocitator to keep it from stalling, any difference in story?
cheers
Mine is stalling a little often at the moment too... ...but when I go from 1st to Neutral... ...and mostly while turning while doing that... ...eg three point turns...
But it's been a while since I got it serviced (damn cash flow)... ...So I think it will be picked up in my next service...
its the afm 100% you probably havent clamped the pod on properly. Ages ago id taken the lid off my airbox to get that gay woosh sound and for about a day the car would stall like urs too until the computer kind of worked out what the hell was going on and it went away. If the car wasnt doing it prior to the pod being installed then chances are its something to do with that.
good luck!
cheers mate, i think your right, i had a glance last night, and i might have found some spots, i really thought it was the computer cracking the shits, but still hasnt worked out the right amount of fuel/air ratio. awell, will pull apart and start again lol.
oh P.S is there a way to reduce the WHOOSH sound the pod makes? it sounds a bit wankish lol
PEACE
