hey folks, ok basicly my car is stalling while im moving, an it tends to be in 5th gear and when im clutching in, thats when this has happend, luckily ive been driving in a straight line because the steering goes when this happens so ive been lucky so far but i need to get it fixed asap, anyone know why and how to fix this?
note i recently installed a pod and put new oil in the gearbox, theres another thread on here regarding the oil i put in but no one has answered and i realy need this solved, basicly in regards to the oil i put in 3 litres according to the help from autobarn, and that worries me alone.
Anyone know whats going on and how to fix this?
cheers
https://www.sau.com.au/forums/topic/239094-car-stalling-need-help/
cheers
Ok thats really weird cause my car just started to do that, out of the blue really but has happened only twice will post if anything knew happens otherwise will be following this thread closley
i forgot to mention it sputters while cruising, like vvvvvv.vvvv.vvvvvvvvv.vv every now and then. also, i was testing it a bit and it only stalls when i hold the clutch in to long when changing gears. the revvs just drop like a rock, so i goto keep blipping the velocitator to keep it from stalling, any difference in story?
cheers
Mine is stalling a little often at the moment too... ...but when I go from 1st to Neutral... ...and mostly while turning while doing that... ...eg three point turns...
But it's been a while since I got it serviced (damn cash flow)... ...So I think it will be picked up in my next service...
its the afm 100% you probably havent clamped the pod on properly. Ages ago id taken the lid off my airbox to get that gay woosh sound and for about a day the car would stall like urs too until the computer kind of worked out what the hell was going on and it went away. If the car wasnt doing it prior to the pod being installed then chances are its something to do with that.
good luck!
cheers mate, i think your right, i had a glance last night, and i might have found some spots, i really thought it was the computer cracking the shits, but still hasnt worked out the right amount of fuel/air ratio. awell, will pull apart and start again lol.
oh P.S is there a way to reduce the WHOOSH sound the pod makes? it sounds a bit wankish lol
PEACE
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
