Hi guys,
Got a photo of the wheels on a car i brought recently and wont be here for 5-8weeks .Im just wondering if anyone has seen them before and what brand they are. I noticed a c or could be a g in the centre but not g-grams or g-games i couldnt find this wheel anywhere. Thanks in advance.
https://www.sau.com.au/forums/topic/239140-anyone-seen-these-wheels-before/
Hi guys,
I quite like them as they have a 'light' look to them. Would look quite smart on the V35 in Silver, which is what they are on, correct?
Good work, where did you get the car?
Edited by Stephen Thorpe
Yes correct silver , buying it thru global hub wont be here for 5 weeks also comes with fijitsubo exhaust / impul cpu / recaro seat
No, it's a unique wheel that rare to see on any car in Australia, let alone a V35! Those wheels are worth a fair bit IMO it's one of the few best looking JDM wheels that suits a V35, and not common as TE37's/GT-C's etc. Good pick!
Rare can be good (exclusivity for your pride n joy) but can be real bad if it ever got damaged. Just don't hit a pothole and bent one of them... you'll probably have a very hard time finding replacement, and may cost a lot of money especially replacing one usually means buying brand new from the manufacturer/authorised dealer. If that ever happens you might as well get it repaired locally if it's repairable but it's not gonna be cheap, it can be more expensive than buying another used set from Japan, depending on the amount of damage done. I've just imported a set of 19" from Japan n the shipping cost alone (on top of rim price) is $900+ via EMS, coming in 4 separate boxes. Just to give you a ball park figure what's it's gonna cost if you ever have to replace one or two of those rims.
Nice combo of aftermarket parts, but be prepare to find std parts, might cost you a bit more to comply with all those aftermarket parts as they're not suppose to be compliable with those parts on... unless you can find a rather 'dodgy' workshop.
The good news is another friend is bringing one in on the same ship so hopefully it will work out. I tried finding out a bit about the impul chip with no luck. Do you think i will notice a difference in performance with this cpu and exhaust system. I.e dyno tune 180rw??
No idea. but I heard they're like a fixed tune ECU so you won't be able to do anything much with it, and I doubt you'll find anyone locally who knows how to tune it, and not sure what local fuel will do to the ECU mapping which was mapped (perhaps aggresively) based on Japanese 100-octane fuel.
I was considering getting one from japanparts.com, but after a rather sketchy email conversation with a Japanese salesperson in broken English about having to bring the car to Nissan dealer for some kind of immobiliser registration, it sounds like a very complicated thing just to get the ECu to fire up the engine, let alone to have it tuned locally, so I decided not to touch any such ECU from Japan.
Thats not good news . I guess i will just have to wait and see . I hope the car will start
I am sure it will, just make sure you use good fuel and maybe watch (and listen) what you are doing for a while. A bottle or 2 of Octane booster might help in the early days too.
1 dyno tune (run) on a cool day, will also help.
If it's already on the car from Japan it might be easier because the Japanese owner would have had done the immobiliser bit at a Japanese Nissan Dealer. If you're trying to fit one on a car that's already here you won't be so lucky as I don't think the local Nissan dealer would care about an import.
Im wondering if i should sell these wheels before anything goes wrong. i.e pot hole gutter marks.
Not sure where you are, but most wheels can be reapaired a mate had 2 18's repaired (bent on inside) for $100ea, from a place that Bob Jane deals with.
The place was in Melbourne and they did a good job, if there was a requirement to have cosmetic damage fixed the price could be a lot more but the dent was quite considerable.
I wouldn't rush to change them...
Yeah always can get repaired . Just a question on compliance i have been quoted $2.5g is that about average ? Im in sydney area :(
Also whats all the gold wiring going around the engine is that for the stero ? I havent seen this on every v35.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
