Hi guys,
Got a photo of the wheels on a car i brought recently and wont be here for 5-8weeks .Im just wondering if anyone has seen them before and what brand they are. I noticed a c or could be a g in the centre but not g-grams or g-games i couldnt find this wheel anywhere. Thanks in advance.
https://www.sau.com.au/forums/topic/239140-anyone-seen-these-wheels-before/
Hi guys,
I quite like them as they have a 'light' look to them. Would look quite smart on the V35 in Silver, which is what they are on, correct?
Good work, where did you get the car?
Edited by Stephen Thorpe
Yes correct silver , buying it thru global hub wont be here for 5 weeks also comes with fijitsubo exhaust / impul cpu / recaro seat
No, it's a unique wheel that rare to see on any car in Australia, let alone a V35! Those wheels are worth a fair bit IMO it's one of the few best looking JDM wheels that suits a V35, and not common as TE37's/GT-C's etc. Good pick!
Rare can be good (exclusivity for your pride n joy) but can be real bad if it ever got damaged. Just don't hit a pothole and bent one of them... you'll probably have a very hard time finding replacement, and may cost a lot of money especially replacing one usually means buying brand new from the manufacturer/authorised dealer. If that ever happens you might as well get it repaired locally if it's repairable but it's not gonna be cheap, it can be more expensive than buying another used set from Japan, depending on the amount of damage done. I've just imported a set of 19" from Japan n the shipping cost alone (on top of rim price) is $900+ via EMS, coming in 4 separate boxes. Just to give you a ball park figure what's it's gonna cost if you ever have to replace one or two of those rims.
Nice combo of aftermarket parts, but be prepare to find std parts, might cost you a bit more to comply with all those aftermarket parts as they're not suppose to be compliable with those parts on... unless you can find a rather 'dodgy' workshop.
The good news is another friend is bringing one in on the same ship so hopefully it will work out. I tried finding out a bit about the impul chip with no luck. Do you think i will notice a difference in performance with this cpu and exhaust system. I.e dyno tune 180rw??
No idea. but I heard they're like a fixed tune ECU so you won't be able to do anything much with it, and I doubt you'll find anyone locally who knows how to tune it, and not sure what local fuel will do to the ECU mapping which was mapped (perhaps aggresively) based on Japanese 100-octane fuel.
I was considering getting one from japanparts.com, but after a rather sketchy email conversation with a Japanese salesperson in broken English about having to bring the car to Nissan dealer for some kind of immobiliser registration, it sounds like a very complicated thing just to get the ECu to fire up the engine, let alone to have it tuned locally, so I decided not to touch any such ECU from Japan.
Thats not good news . I guess i will just have to wait and see . I hope the car will start
I am sure it will, just make sure you use good fuel and maybe watch (and listen) what you are doing for a while. A bottle or 2 of Octane booster might help in the early days too.
1 dyno tune (run) on a cool day, will also help.
If it's already on the car from Japan it might be easier because the Japanese owner would have had done the immobiliser bit at a Japanese Nissan Dealer. If you're trying to fit one on a car that's already here you won't be so lucky as I don't think the local Nissan dealer would care about an import.
Im wondering if i should sell these wheels before anything goes wrong. i.e pot hole gutter marks.
Not sure where you are, but most wheels can be reapaired a mate had 2 18's repaired (bent on inside) for $100ea, from a place that Bob Jane deals with.
The place was in Melbourne and they did a good job, if there was a requirement to have cosmetic damage fixed the price could be a lot more but the dent was quite considerable.
I wouldn't rush to change them...
Yeah always can get repaired . Just a question on compliance i have been quoted $2.5g is that about average ? Im in sydney area :(
Also whats all the gold wiring going around the engine is that for the stero ? I havent seen this on every v35.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
