i think the question would be why do you want to.
Generally they flash fast to let you know that one of your globes is blown, so what you have to do is reduce the amount of current that is being drawn.
If you want to do this the best way is to install LED lights but not the ones that are ready made, you will have to make your own. The ready made ones have extra parts in them that creates the same current draw so they flash at the normal rate.
Hope that helps
Cheers
Ross
I don't think they flash to let you know a globe has blown, I think it's just a case of that's what happens when a globe blows and the current draw decreases..
Maybe look at off the shelf flasher units, I'm not an autosparky so I don't know whether they would all be the same or not..
All new cars are designed this way to let the person know that a indicator light is out, it is a saftey feature.
You do have a good point with the flasher unit it is another possibilty but will be hard to find one that will fit and do what you want it to do.
yeah the guys above have told u, basicly less current draw so the flasher unit (capaciter) is discarged alot slower hence can reboot up faster because it don need as much charge:)
Its not a capaciter (well not in any i have seen) they operate using a bi-metalic strip. When one glob goes out - less current draw = less heat, making the bi-metalic strip bend in a smaller arc then cooling down and making contact in a shorter time hence the 'fast' flash.
Cheers
Ross
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
