I recently acquired a consult -> USB cable and discovered Code 21: Ignition Signal Circuit. Im from the USA and i put this rb25det neo into an s14. Im running the car on a Stagea R34 Automatic ECU. I did a search on the forum and did read some other threads with a similar problem, but none helped. The motor has been running for a few weeks, but I cant get cylinder 1 to fire. I rotated the coils and plugs around so thats not the problem. Power voltage to coil 1 is your normal 12-13.5V, but the trigger voltage was only .3V (all other coils were ~.8V). I know my problem is either in the ECU or Wiring Harness, but i also read a thread on here where someone had a bad ground? Should i test the continuity to coil 1?
What do you guys suggest. Ive pretty much tried everything I can think of. I dont have access to try someone elses ECU or Wiring harness, as there are only a handful of these motors in my entire country. How often do these ECUs go out? I tried to test the voltage coming out of the Ignition Signals to each coil (directly on the ecu), but I couldnt get a reading for the life of me. Besides this one problem, the motor starts, idles, and drives as good as it gets (with 5 cylinders that is).
Please help me out here gents!
https://www.sau.com.au/forums/topic/239162-rb25det-neo-code-21-cylinder-1-dead/
I don't think you can check the ecu trigger signal using a multimeter gotta use oscilloscope. I've done this on my car coz it was misfiring.
The signal should have a sawtooth sorta pattern (i think it's current control). If you don't get a signal it's proabbly either the wiring for the trigger signal is stuffed or the ecu itself is stuffed. You can check the wiring by just checking teh resistance from teh corresponding ecu pin to the coilpack connector for your dead cylinder.
How do you know the cylinders not firing anyway do you get blacksmoke out the exhaust?
I know because ive disconnected the coils during idle and the motor doesnt change at all. I rotated the coils and plugs, so I know its either wiring or the ECU. How would I check the resistance on the wiring to coil one? Just complete the loop by running a wire directly from the coil to the pin on the ecu?
Thanks for the help my friend, I do appreciate it.
Do you have a pinout diagram? This may be the one although there are variations:
http://www.skylinesaustralia.com/forums/in...st&id=31087
Yes i have the pinouts, thanks though. Im very surprised nobody has ever had this problem before?
Open the ECU and check out the two large power transistors bottom left (plug facing you) up against the side, heatsinked to the body of the ECU.
I'm guessing the one of them will show signs of burning out, will be brown/charred and very brittle....to the point when you remove the heatsink to get a clear look it will break.
That's my guess, I've seen it before on R34 ECUs, hopefully I'm wrong.
4x now i have seen error 21 keep a car off the road for months with the owner scared to drive it, 4x now i have switched to new coils and its been fine.
that being said, if your cylinder is dead completely, it may also be the wiring to that coil
I dont think it is the coils, as when I rotate them, the same cylinder wont fire. Im guessing at this point it must be wiring.
so disconnect the ecu, isconnect the bad coil clip, and use the pinout diagram and a multimeter on the contnuity setting to get a simple answer of wether or not the cables get to the other end or not. with ecu and battery off, you can poke wherever you want and cant hurt anything.
check that one pin goes to ground, one goes to the battery, and the other will be the trigger for example if there are 3.
use a bit of speaker wire or something to go up from the ecu to one of the pins, and then find the other end on the ecu.
Well i have continuity between the ecu and the coil on all 6 coilpacks, so I'm definitely thinking it is the ECU at this point correct?
And BTW, it's cylinder 6 that wont fire, not cylinder one. I was backwards on my counting order.
  • 9 years later...
  • 1 year later...
8 hours ago, bistratoaie said:
I seem to have the same problem and cylinder 6! Anyone got any solution?
I just read everything in this post, seems to me all the answers are there. It boils down to continuity or fried ECU.
  • 5 months later...
Turns out piston #6 had shat itself and got a little hole in it as fuel was just dumping into the sump, have done a rebuild with new forged pistons, rings, bearings etc and she's running beautifully. Ignition circuit also goes hand in hand with knock sensors I believe, I had an ignition fault code 21, and tried everything to sort it after buying new splitfires, spark plugs, coilpack harness, AFM all that jazz, turns out one of my knock sensors was crushed and that was my ignition problem solvered ☺️
  • Like 1
It occurs to me that a compression test might have been a good idea. Is that how you found the fault?
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
