Item:
A. R33 GTR RB26 stock coil cover and timing cover, coil cover is perfect, timing cover has a few marks and has fresh satin black paint.....would be good for polishing, or painting, or whatever.
B. R33 GTR Genuine Nissan 400R clear front indicator lenses, perfect condition, these go for about $130 each usually on nismo.com.au
C. Apexi EL2 Boost guage, mechanical, perfect condition, the mounting base has been bent to suit where I wanted it, but could be reshaped easily, all wires and lines are included.
D. Trust GREX gearknob, suit Nissans, blue h-pattern sticker on top, nice knob to drive with
E. Lightweight wheel nuts, set of 20, black, some marks and chips, but a quick coat of paint would fix that, extremely lightweight, came with my Volk TE37's that were on the car when I bought it.
Age: all less than 12 months, except covers
Condition: as stated
Price:
A. $120
B. $150
C. $120
D. $50
E. $50
To Fit: GTR's or whatever an RB26 is in, or any turbo car or Nissan's
Contact: PM
Comments: none.
Sorry, my mistake the wheelnuts aren't quite so light weight, they are lighter than normal, but not like RAYS or anything, however they are a full set, with lock nuts.....drop to $20 for the full set.
Knob looks like this one
RB26 covers are sold and gone.
The wheels nuts/locknuts are not the lightweight ones I thought they were, they are just a basic set of black nuts, they are lighter than normal, but nothing like the lightweight RAYS nuts which are rediculously light....no pics, they look like wheelnuts, and I have reduced the price to $20 for the set.
Covers are sold.
Edited by QIK_GTR
ill take them. pls pm me your pickup details...
pics plz
pics of what? The boost guage or the clears or both? The boost guage is a regular black faced, Apexi EL2 boost guage and the clear fronts are just clear version of the stock orange ones, I can get pics if you really require them to see what they look like.
Have you got the black indicator plate for the standard GTR front bar?
No, they are just the clear lenses/housing that fits into the black plate.
Guage is sold.
Clear front indicator lenses/assemblies left to go, someone must want these, ditch the ugly, old, mid 90's orange things and go clear.......
Lenses $120 posted, want them gone, last thing to sell, these are genuine Nissan clears, worth more than double my asking price!
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
