  • Replies 42
Damo,
I too have been keeping a record of my fuel consumption over a long period. I started with cat back exhaust and pod and have kept a record of when I did mods, long drives etc.
From memory im getting about 13L/100km in city type driving.
Mods include full exhaust, EBC set all the time at 0.6bar, high flow turbo, BOV, pod, clutch, tuned powerFC, FMIC.
When you post yours up, i'll post it in the same thread for comparison - mine is in excel format.
Mark
i have manual r33, stock boost, cat back exhaust and air pod....
i consistently get 450km with a bit a stick, about 550 driving like a granny...
have tried optimax for a year, just changed to BP ultima, havent noticed much difference yet but still keeping an eye on it..
Originally posted by WLD747
how you get so much kms im freaken out.
ok 250KM MAX out of 40L is bad so do i need to replace anything
like my AFM.  why is it rich; will a safc fix it
cheers
ak
Whats with the 40L tank?? 250km out of 40L is not all that bad...its not great, but not bad. I regularly get 400-450km out of 60L, where you would be getting ~375km.
The fuel gauge in the R33s is a little deceptive. The empty line does not actually indicate a full quarter. Mine usually does 350km when the needle hits the empty line, then 50km later the fuel light comes on. I can usually drive around for 30-50km with the fuel light on.
if u r concerned about fuel consumption u should drive a none turbo like a celica then u'll get 600 k out of 50 lts or itegra about the same . when u drive turbos u dont worry about fuel , try driving a hot coome then u 'll see how much fuel u use . 25-30 lts per 100 km .
33's and 32's don't all chew heaps of fuel.
Some are spot on the specs as released from the factory i.e 10.5l/100km's for the R32. Mine appears to be pretty spot on as are some others. BUT there are some out there that get simply crap fuel consumption.
Good work MRK25T, Makes mine look pretty simple. How did u give a direct link to the xl file. When i tried to attach the file it said only certain formats are allowed and that was not one of them. Hence I had to zip it.
Ok just got a EL Falcon Oxygen Sensor - Very similar to R33 one. Costs $77.00 at bursons. The original r33 from nissan costs $280 (No Thanks). Got my mechanic to cut the r33 sensor and soldier the el falcon one on.
And guess what. My fuel gauge is barely moving now, i cant believe it ive driven at least 100km and only a very little drop in fuel. Very good consumption now.
So now i reckon ill get 500-600km out of a tank that i used to get 250km out of before. I am still yet to clean my afm so hoping for better consumption.
Oh yeh power is that same as before. Hope this help guys. And if you get crap consumption go and get it changed.
Cheers
AK
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
