Hi guys'n'gals
not really Skyline related, but there's lot of tech/it type people around these parts... and asians :P so i figured there would be some mobile knowledge :D
my Sony Ericsson T30? (the pearl white one) went for a swim (in the kitchen sink) about a month ago and all i want to do is get my numbers/contacts off the phone.
My sim is currently in another phone and i've only now realised that after the sim gets full (bout 220 entries i think) the numbers are then saved on the phone so most of my numbers in seems are on the Sony Ericsson.
I've tried turning it on, and it seems to work, but the screen is like a washed out white and i can't see sh*t, so i can't read the numbers and write them down manually.
Does anyone know how to retrieve this info? Or a place i could take it to? the phone seems to still work, just that the screen is farked.
The phone does have bluetooth, not sure if that is of any help in this situation.
cheers
chinny
Install the Sony Ericsson PC Suite (on a CD which probably came with your phone, in the box) and follow the instructions that it gives you. Then, when the time comes, plug in your phone via the supplied USB cable and transfer your contacts (via the synchronise option) to your computer.
You should then be able to view your contacts in Microsoft Outlook - or whatever you told it to go to in the synchronisation options.
COmmiserations man. I once had a Sony-Ericsson 810W that set me back $850.
3 weeks later it fell off the side of the boat and into the (salt water) drink.
Although I immediately flushed and soaked it in 600mls of Evian, it never recovered.
3 of the charge pins coroded away.
Many months later, the Communications Clinic on North Rd, Ormond said they could replace the board & pins on it.
Still on the cards to do this as the phone was a cracker.
you said it seems to work.. if it can turn on then thats a start...
a few years back my mates little cousin decided to take his 8210 and drop it in the toilet while we were out... recovered it, washed it... and similar thing happend.. screen was all washed out and faded... cant remember where he took it but they replaced the screen and it was fine...
look around for phone repair shops or soldiering places... I once got a phone unlocked and screen replaced by this small store in an arcade on bourke st... can give you the addy, not sure if the place is still there though.
Fuck the Sony PC Suite garbage. Install MyPhoneExplorer. It'll read everything off the Sony if you install the USB drivers for it... SMS's... contacts, even your decently dialled and incoming calls list.
Hey, that looks pretty sweet. Sony Ericsson always freaking crashes for no apparent (real) reason when I unplug my phone, even though I eject it properly from the computer first.
I'll give that a look when I get home. Thanks! :P
Edited by rh1n0
thanks shan, i'll give it burl... IF i can find the cable :P i would like the sms's as well...
The one i had, T30 or whatever... i had since 2002 and was going fine until mid this year, so i reckon i had a pretty good run. Pre-historic phone by todays standards, but still did everything i needed it to do.
now, has Sony E changed it's data cables over the years???
At least your phone still turns on. Mine is totally dead. Dad decided to take my 8800 for a spin down the road with it on the back of his car. he got pretty far with it too before it fell off. now i got it back and its totally smashed up.
turns out the imac at home as bluetooth, whaddayaknow :P
turns out Macs are still shit and have a useless supply of programs written for it, ie MyPhoneExplorer...
i can get the iMac to recognise a Nokia 6230 that i'm using in the meantime... is there are good program, for mac, that will let me go in and delete ALL my sim #'s from the mac? Otherwise i'll have to go through # by # manually.
oh, can get the old wet SE to link up with a program called 'phoneagent' but the phone always seems to reset itself automatically before it can finish getting all the contacts >:D - so at this stage, i need to do it via the Nokia, but don't know a good management program for mac for Nokia
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
