Hi all,
I am in the process of replacing my R32 sedan driver door as my current door is all dinged up. Now heres the problem:
I am having trouble locating where I can unplug the driver door wires so I can remove the door. Can someone tell me where to locate and unplug those wires? Do I need to take apart the dash to get to the wires plug?
Edited by nwa32
https://www.sau.com.au/forums/topic/239259-r32-driver-door-removal-help/
Hey man,
There's no way of disconnected the loom. It's all connected to the main body harness if you know what I mean.
You have to take off your door card, unplug everything, and then feed the door loom through that hole you circled.
Hope that helps.
Hey man,
Hope that helps.
uuhhh, what are you on about?
there is a rubber plug if you follow that black cord back to the chassis of the car. you unplug that and there are two connectors which you disconnect. i have attached a really crap photo of the black rubber thing and the two connectors.
then just feed the whole lot back out through the hole and you can take your door off
also you may or may not have to take the front 1/4 guard off to get to the bolts that hold the door on. and its also an idea is to take the pin out of the thing that holds your door open before you take the bolts off. im talking about the rod thats just under the bit that you circled
trust me, its a bitch if you don't take it off first.
Cheers for the feedback.
I have decided to unplug it this way as I want to keep the original door loom. Just need to find the time to give this a try.
The problem was that I can't follow the black cord back to the chassis so I can disconnect the connectors/plugs. I tried to reach for the connectors/plugs from underneath where the pedals are but they are like hidden behind. Did u have to take out the dash to disconnect them?
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
