Hey,
I have taken all boot trims out as the boot seals were leaking. After fixing the seals I'm stuck with another problem which I cant seem to work out.
I have put all the side trims back and the spare wheel.
The only problem now is the thin wooden bit that sits under the carpet
On this wooden sheet, there seems to be two big (hard foamish?) blocks
Now i assume these blocks would obviously go facing down
I also assume the arrow pointing out is the way facing the boot.
I have tryed for about 30minutes trying to get it in, but the foam blocks are blocking it from sitting straight
I contemplated cutting the things off but then thought they must be there for a reason (to stop rattling?)
I have taken pictures to show you what I'm talking about.
Could someone please help?? lol
The joys of having an N1.
I have no boot trim :P
Though the foam should be facing down, and the handle to lift the wooden panel itself should be closest to you, not the back seats.
Once you have done that, it can only sit one way, and if it doesn't there's somehing else in the way.
