How injector you talking about?
What fuel pump setup do you have?
my 740's have run out of puff a fair bit short of the power you have, but i only have a tomei intank.
I have a walbro 255 intank feeding directly into a bosche 044 external pump with nismo 740cc's
the PFC is going up to 1.182 on 20psi, and the max is 1.499. plenty left. i did not check what injector duty i am getting, i am thinking 80%
Another thread that looks interesting form Evolutionm net .
http://forums.evolutionm.net/showthread.php?t=372766
Enjoy , A .
will check it out
i got to about 90% duty cycle but that is not a true indication because my fuel pressure was dropping. i got to about 320 kw before this started happening. so the 600cc injectors could probably make more power but if i have to upgrade my fuel pump i might as well change my injectors at the same time. i'll probably go for some 1000cc's.
this is very cool topic! anthony, if you could post up a dyno graph once you have done your final power tune on e85 vs pulp.
our supra race car used to run on vpower racing but now has to use et 102.
then we will take this to the ute racing board for a comparison. mayby next year we will run the utes on e85. that will give it some decent exposure. concidering we get almost the same tv as v8 supercars....
but yeah, pulp vs e85 comparison. looking forward to it! ps.. might have to get those indy blues after all heheh
I would say you are running out of fuel pressure/flow. You might have to upgrade pump/power supply.
depending on what power you are looking to make, you may need to upgrade the fuel line also.
i swear i am going crazy, more dreams!! this time i get to the RTA to do the emissions test and my Datalogit stuffs up so I cannot load the emissions tune i had so I had to try and fix it up and re-tune it quickly with the hand controller.
I cannot wait till all this is over. lol and that better not happen today!
Your a weirdo lol.
Hey Anthony,
ive been reading your topic very interesting and interested , i found this while reading about ethanol this morning. Supercars to run Ethanol 2009 see link. cheers
http://qcl.farmonline.com.au/news/state/ag...es/1333229.aspx
yeah i know.. they saw my testing and the great results i have been getting and they want to be more like me..
CSR Sugar chief executive Ian Glasson said every litre of E85 made from CSR Ethanol produces less than half the CO2 emissions than one litre of petrol.
Well we will see today... Has there been any real tests so far? with real results? I have a passed emissions test with 98 octane and i will have a e85 test this afternoon!!
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
