wondering if i should try e85 on my new engine build. running a fully built rb25 with cams and all the other goodies needed, running a turbonetics gtk550 so its slightly larger then a gt35, will prob run about 24-27psi. any idea what power i might beable to hit?
Edited by tets
Got this email recently from a well known magazine feature writer about his engine (SR20) and the switch from premium to E85.
Got it tuned it last night. On 19psi power went from 289kW to 311. In the end we turned it up to 24psi but the injectors maxed out and exhaust housing on the turbo was starting to choke. However it made 342kW and the increase was from the word go, not just top end. The car wheel spun on the dyno for the first time ever, it’s very aggressive!
Went for a drive with him a few Fridays ago, that car is an absolute animal!!!! For its setup, that thing is incredibly fast, 135mph with a GT3037?
Also Adam at JEM has E85 in a massive drum. $1.50L
Not sure if it was mentioned or not but the V8 Supercars are switching to E85 for next years championship should prove some interesting results and possibly even more demand for the bogan crowd (we all know there is a lot of them, some don't even know it...) which means import drivers might also benefit. Interesting article in the Current CAMS magazine too that the fire extinguishers will not need to be upgraded as dry chemical powder and foam are fine.
so ant, after your testing do you recon i'd be able to switch between the 85 and 98 regularaly if i have a pc and datalogit?
and will i have to change the fuel filter every time?
yeah piece of piss. just load the new map when you stop at the bowser, make sure your tank is as empty as it can get.. then load up the map upload it to your ecu.. fill up and go!
sweet... where can i cag datalogit?
hey mate sorry for the late reply.. but i been at the nats.. probly pissin ppl off more then anything but having a damn good time as well :happy:
ii will
do a search on google for datalogit, the joint is in NZ and they do actually send out your datalogit afr you pay for it in a pretty reasonable time frame, ppl have reported that the product has been recieved in the mail before any kind of confirmation of payment or order completion at all. So pay your money and the unit will arrive quicker then expected.
Cheers
the chemical dude next to my workshop can jet me denatured ethanol (meths) for $1.30/L E98 anyone?? :P
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
