Guilt-toy Now Running On E85 !
my setup needs some attention. I am running the stock mspec front bar and have not chopped out the reo bar because i like my car to be legal.
The oil cooler is mounted on the front of the air con condensor, so its heating up there, i added a air con thermo fan and have replaced the clutch in the engine fan.
Its just that the radiator cannot get enough air from the front. its a Mspec radiator as well.. I need to move the oil cooler and install another thermo fan i think.
Try fitting an alloy radiator and a Nismo thermo stat.
Sounds like i have a similar set-up to yours, but i have cut the reo :), and my temps are mainly stable at 64-68deg. The highest i have ever seen it was 86deg at a drift day.
PS: Bonnet vents help alot too ;)
Who did you get to fill in the missing bits around the inside edge of the bar openeing?
A plastic welder in East Keilor, VIC.
I think they have closed down since, but you should be able to find one in the yellow pages.
im keen to give it a go on the track, will c the EPA about it considdering the fact that i have no cat... ill need to do some mods before she is finished however will need a good tuner. Guilt-Toy seems to have his head screwed on with loktite lol might see him about it....
Sounds like i have a similar set-up to yours, but i have cut the reo :banana:, and my temps are mainly stable at 64-68deg. The highest i have ever seen it was 86deg at a drift day.
PS: Bonnet vents help alot too :)
nice setup! i do have a alloy radiator, its a mspec one. my temps are okay on a 40deg day when my air con is off, as soon as i turn the air con on the temps go through the roof... got up to 102deg today (cycle idle was off)
I got a new genuine nissan thermostat as well.
My oil cooler is on the other side so my fan is where your oil cooler is.
are you running a rediator shroud? I broke mine and havent been able to find one recently and I find my temps sit around 86' compared with 81' when I first fitted the ally radiator with shroud
Hey Al have you got more pics of your car somewhere its on f*kin clean gtst!
yes i i do have the shroud.. seems my car runs a bit hotter for some reason... might try some better coolant or move the oil cooler? my oil cooler is heaps bigger then that one on Als car
not to mention a std air box
his injectors are maxed out tho, he should think about an upgrade, i suggested sard 850's would give some nice headroom.
Just an update for those interested, i have noticed this thread has been a bit quiet of late.
I have sold the 555's and in the process of purchasing SARD 850's (should receive mid next week).
Also purchasing 24psi actuator off a fellow member which i should recieve early next week also.
POD filter has just been bolted back on.
Be interesting to see how it goes holding the 24psi boost with plenty of fuel and air. Adrian will be tuning again (your a legend mate whats this make it 5 or so now). If it feels noticeably different it will getting run up on the same dyno again. If not it can wait til next months dyno comp.
I'll add my 2c too.
We finally fired up my RB25DET at the end of last week using 910cc inj' and running E85 for the first time.
Scaling ~25% fuel out of the map for the old 550's saw it start up and purr away like a kitten.
And now that the Adelaide temp's have dropped from 'insanely hot' to mid 20's I'm expecting a dyno number sometime next week. Still have to do a bit of tidying up after the rail and injector change, but it all looks neat enough.
:) Ha-ha. He's a man with a memory like an elephant. I was considering upgrading the cement to top quality 300*300*40 pavers, as not only do they give a nicer Autosalon style boot display, but they also allow more adjustment in weight distribution :)
GT: May I suggest attempting to swap your radiator for a stock Koyo one?
Have seen issues from Alloy rads not dispersing heat properly.
Either that, or chuck a volt meter in the coolant whilst engine is running, and against battery earth... Do not let the probe in the water touch metal of radiator.
Then do a test from rad itself to battery neg...
If you get a voltage usually about like 0.5Volts on either, throw an earth strap on the rad.
you mean a stock nissan one? i do have a spare actually.. and as for the earth, i already have a earth strap on it.. put that on a couple of weeks after i got the alloy radiator...
I am getting one of those swirl pots, to go on the cooling system. when i turn the car off i can hear bubbling in my coolant system.. just noticed it.. maybe the top mount turbo is causing air in the line and causing the extra heat?
is it bad to run the engine at 100deg? or 97?
Brief stints at those temp's are nothing to be majorly concerned about, but if it's a regular occurrence I'd be looking at rectifying the situation, GT.
It's not something simple like a dud radiator cap is it - I know it's one of the first checks you would do, but I thought I'd ask.
Bubbling is also an indicator of head gasket or head problems which would also cause it to run hot.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
