Guilt-toy Now Running On E85 !
I would be tempted to fit bigger injectors and lean on the stock turbo a bit. The e85 will give you more power whilst running lower exhaust temps compared to ULP, so it should reduce the heat load on the exhaust wheel. I wouldnt be surprised to see 220rwkw at 15 psi with a stocker on e85
Ok last question.
After the injectors are installed, a decent tuner should take how many hours to do a full map on e85? keeping in mind I have it tuned on 98 at the moment. Plus I read that fuel filters were getting changed every few weeks for a while after is that true?
Apart from that all else should be sweet though right.
Its all the same stuff.
E85 either comes from CSR or Manildra. Unless Powerplus are making it themselves which i doubt.
As we were going through installing the new fuel system all parts that were taken off the car were inspected, everything looked great :)
The injector O-rings are not brittle and have no sign of cracks or premature wear at all. I was comparing them to a new set that i have and i cannot tell the difference between the two.
To save you scrolling up on this page, here it is again :bunny:
Mines not the injector O rings that are the problem, rather the O ring between the fuel filler and the tank has swelled and no longer seals.
The car is a 1990 but even a brand new nissan o ring seems to swell up and fail to seal. Perhaps their manufacturing changed in the r33 series of cars?
didn't bother doing a cold start on mine....
it starts....
eventually
I jack up the cold start enrichment by around 25% at -10C and +10C, then 15% at +30C and finally 10% at +50C. I leave 80C alone, although some guys have found adding 5% works OK there as well.
You might want to have a look at the cranking time, it depends on your injector speed and type. Have a play, you can't hurt anything, after all E85 doesn't contaminate the oil like petrol.
Cheers
Gary
ok
1. gary... you're alive!
2. thanx man, would have a look but the car needs another tune on e85 anyway as we found a split cooler hose was present at the time of the last one... i'll pass those values on to trent.
wonder how much more my injectors have in them..... they were pretty far on 311rwkw with e85 cant remember the max dc atm (not 100 lol), but should be looking @ 325-330rwkw if they can make it...
ok
740's??? mine maxed out at around 335 340rwkw
Haven't been on here for a while and last time i was there was talk of unavailability issues?
How's that all looking now? Who and where's stocking the good stuff?!?!?!?!?! (In Vic)
My car is going in in a month and i sure as hell want a re-tune on E85 but it'll be availability dependant!!!
Cheers!
My 555's maxed at 337rwkw on E85...
I have upgraded to 850 Sards and am now seeing anywhere from 80-85 inj duty on my Power FC and making a consistant 350rwkw on E85 with a base pressure of 43.
Your 555's still have more in em on E85 joeyjoejoe imo.
Maybe the 2 Mainlines and 1 DD were reading high who knows but thats my experience so far.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
