Guilt-toy Now Running On E85 !
Ok, got some 750cc injectors on the way for my E85/BP98 50/50 mix...
I have two choices of E85 over here in WA... Either Powerplus for $650 or CSR for $550
My question is which one? Is the Powerplus really worth the premium?
I got the same prices for these 2 this week Simon, im probably going to go for the CSR as the tuner im using suggested to get it from rpw and as far as i know thats where he gets it from.
whos tuning yours?
whos tuning yours?
Sean from Allstar... I assume that you're getting yours done at Hyperdrive?!?
I paid $150 for a drum of CSR. :ermm:
Thanks Birds.
So when's caltex releasing this shit do we have a date? I can't find any specific dates
I was told, "The end of the month" by 2 servos I rang but Caltex thought they were already operating. I guess we will find out next week...
Nope sean aswell.
just got my 1450cc injectors delivered, so a quick run over the pits, strip the pit crap off and then all thats left is for sean to work magic on my 26/t04z/e85/26psi.
will let ya know how i go.
I see your 1450cc and raise you ID2000s :)
NOTE: My Rochester 1000s are for sale if anyone is interested. $500 Delivered FIRM.
Well, the Caltex pumps seem to be up and running, they wouldn't tell me the price over the phone, can anyone near the Clayton road servo call past and check the price?
I will try and call in for a fill and let you know how it runs, and if the wideband likes it. :)
yeah i saw a scrolling thing on Sky news yday morning saying holden has relased their flex-fuel cars - surprise surprise nothing on the holden website, but it seems to be official so assumed the Caltex stations were up and running.
definitely let us know how you go :)
i do have something to ask the people of this thread, something that a potential buyer of my car has asked.
He wanted to know that if the car was on the E85 map, and for whatever reason you couldn't change it (laptop died, USB consult cable not working, etc) would you be able to drive it on 98 etc?
I thought it might be ok if you took it VERY easy as there would be a lot more fuel yeah? but also more timing? i thought maybe with the extra fuel in the tune it MIGHT make it safe to drive very sedately despite the extra timing.
thoughts?
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
