Ok, got some 750cc injectors on the way for my E85/BP98 50/50 mix...
I have two choices of E85 over here in WA... Either Powerplus for $650 or CSR for $550
My question is which one? Is the Powerplus really worth the premium?
I got the same prices for these 2 this week Simon, im probably going to go for the CSR as the tuner im using suggested to get it from rpw and as far as i know thats where he gets it from.
whos tuning yours?
whos tuning yours?
Sean from Allstar... I assume that you're getting yours done at Hyperdrive?!?
I paid $150 for a drum of CSR. :ermm:
Thanks Birds.
So when's caltex releasing this shit do we have a date? I can't find any specific dates
I was told, "The end of the month" by 2 servos I rang but Caltex thought they were already operating. I guess we will find out next week...
Nope sean aswell.
just got my 1450cc injectors delivered, so a quick run over the pits, strip the pit crap off and then all thats left is for sean to work magic on my 26/t04z/e85/26psi.
will let ya know how i go.
I see your 1450cc and raise you ID2000s :)
NOTE: My Rochester 1000s are for sale if anyone is interested. $500 Delivered FIRM.
Well, the Caltex pumps seem to be up and running, they wouldn't tell me the price over the phone, can anyone near the Clayton road servo call past and check the price?
I will try and call in for a fill and let you know how it runs, and if the wideband likes it. :)
yeah i saw a scrolling thing on Sky news yday morning saying holden has relased their flex-fuel cars - surprise surprise nothing on the holden website, but it seems to be official so assumed the Caltex stations were up and running.
definitely let us know how you go :)
i do have something to ask the people of this thread, something that a potential buyer of my car has asked.
He wanted to know that if the car was on the E85 map, and for whatever reason you couldn't change it (laptop died, USB consult cable not working, etc) would you be able to drive it on 98 etc?
I thought it might be ok if you took it VERY easy as there would be a lot more fuel yeah? but also more timing? i thought maybe with the extra fuel in the tune it MIGHT make it safe to drive very sedately despite the extra timing.
thoughts?
It would run like crap with black smoke billowing from the exhaust, much like all the other skylines I see. :)
Thats why I like the Emanage Ultimate's dip switches for changing maps. A switch would be perfect.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
