Guilt-toy Now Running On E85 !
I'm very much limited to what NIStune can do.
Other than the fact that I would have had a bit more stuffing around to sort nistune on a 33, this is why I spent the bigger dollarz and went with the ViPEC :)
OK so since it looks like nobody want to buy my rims lol, I'll probably get myself new a new CAT of some description, and a wideband from wbo2 in the coming months....
and some ku36's, coz these Maxxis tyres SUCK with power.
sorry if this has been covered earlier, my wideband doesnt read in lambda so im stuck with the gasoline calibrated AFR's.
what ive read is you divide your GAS AFR by 1.5 to get your actual AFR on E85.
it looks like the AFR's on your GAS calibrated AFR dont change too much, ive ripped a table from: http://www.e85forum.com/ntopic777.html&amp...721aef0b42b578a
Idle/Cruise = 14.7 - 15.2
Light Load = 12.5 - 13.2
Pre-WOT load = 11.5
WOT = 11:1 - 10.5
these figures are for gasoline calibrated AFR's.
does this sound right to the pro's?
update on my E-Flex adventures.
Car feels AMAZING to drive, more torquey, smoother throughout the entire rev range.
290rwkw with siemens deka 550cc injectors, walbro pump. still more left in the injectors, and pump seems to be keeping up just fine.
i ran a walbro the whole time i was on E85, 740cc injectors - never any issues, prob about 18months straight of exclusive E85 use - bout the same power as well
Your opinion is invalid as you have shown mental instability when you sold that absolutely amazing R34 of yours. Shame on you.
lol :blink:
Oh I didnt realise that result was on E85! Did you have a tune on 98 as well?
He only ever got his 98 tune results once I believe, and it was with a really restrictive intake so it only made 266rwkw when the piping was killing airflow.
This tune was on E-something....like E70 or thereabouts
Here's a quick excel of my pre and post caltex e flex fuel :blush:
NOTE!!! the Caltex E-Flex was actually run with LESS boost
PULP 98 spiked up to 21psi then dropped to 15 and held
Caltex E-Flex spiked to 19psi then dropped to just under 14psi by redline (where peak power was made)
I used the formula ((Speed/28)*1000) for the revs. Not exact but very close
almost 50rwkw gain through the midrange and this is only e70 at the moment...
giggity!
Yeah Pat your results make me cry. LESS boost, and HUGE gains in midrange. Fark I gotta get up early to fix my cooler piping tomorrow, not driving my car hurts. Can't wait to make the switch as well, just gotta get a bloody wideband :blush:
fark.. you guys are still going with this :thumbsup:
I been in Abu Dhabi in UAE tuning, fuel here costs 50c a litre for 98 =) and money is never a problem for guys wanting to build cars...
how different is the Caltex stuff to the United stuff? With e85 i never had any starting issues, only difference was a extra 4 cranks of the engine and that was it.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
