I'm very much limited to what NIStune can do.
Other than the fact that I would have had a bit more stuffing around to sort nistune on a 33, this is why I spent the bigger dollarz and went with the ViPEC :)
OK so since it looks like nobody want to buy my rims lol, I'll probably get myself new a new CAT of some description, and a wideband from wbo2 in the coming months....
and some ku36's, coz these Maxxis tyres SUCK with power.
sorry if this has been covered earlier, my wideband doesnt read in lambda so im stuck with the gasoline calibrated AFR's.
what ive read is you divide your GAS AFR by 1.5 to get your actual AFR on E85.
it looks like the AFR's on your GAS calibrated AFR dont change too much, ive ripped a table from: http://www.e85forum.com/ntopic777.html&amp...721aef0b42b578a
Idle/Cruise = 14.7 - 15.2
Light Load = 12.5 - 13.2
Pre-WOT load = 11.5
WOT = 11:1 - 10.5
these figures are for gasoline calibrated AFR's.
does this sound right to the pro's?
update on my E-Flex adventures.
Car feels AMAZING to drive, more torquey, smoother throughout the entire rev range.
290rwkw with siemens deka 550cc injectors, walbro pump. still more left in the injectors, and pump seems to be keeping up just fine.
i ran a walbro the whole time i was on E85, 740cc injectors - never any issues, prob about 18months straight of exclusive E85 use - bout the same power as well
Your opinion is invalid as you have shown mental instability when you sold that absolutely amazing R34 of yours. Shame on you.
lol :blink:
Oh I didnt realise that result was on E85! Did you have a tune on 98 as well?
He only ever got his 98 tune results once I believe, and it was with a really restrictive intake so it only made 266rwkw when the piping was killing airflow.
This tune was on E-something....like E70 or thereabouts
Here's a quick excel of my pre and post caltex e flex fuel :blush:
NOTE!!! the Caltex E-Flex was actually run with LESS boost
PULP 98 spiked up to 21psi then dropped to 15 and held
Caltex E-Flex spiked to 19psi then dropped to just under 14psi by redline (where peak power was made)
I used the formula ((Speed/28)*1000) for the revs. Not exact but very close
almost 50rwkw gain through the midrange and this is only e70 at the moment...
giggity!
Yeah Pat your results make me cry. LESS boost, and HUGE gains in midrange. Fark I gotta get up early to fix my cooler piping tomorrow, not driving my car hurts. Can't wait to make the switch as well, just gotta get a bloody wideband :blush:
fark.. you guys are still going with this :thumbsup:
I been in Abu Dhabi in UAE tuning, fuel here costs 50c a litre for 98 =) and money is never a problem for guys wanting to build cars...
how different is the Caltex stuff to the United stuff? With e85 i never had any starting issues, only difference was a extra 4 cranks of the engine and that was it.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
