There has been no fuel variation to speak of since e85 was introduced, as long as you run the same brand and fatten the fuel map a little it will run fine.
I predict 300kw with crazy response. :)
Well i plan to use caltex eflex which is closer to E70 i believe as i have several of them not far from my place. Yes the main goal of the car is heaps of response, mid-range power is the main concern :D
Also guys i know this is probably crap but wtf is this? must be magical like an ebay chip :D
http://www.ecofuelbox.com/en/6-Cylinders-Ethanol-e85-Kit.html
Edited by Super Drager
Bloody hell i'd be happy with anything around 270-280kw as i'll get bigger huffers on it one day to make more, but E85 seems to be the way to go if you want the best out of it. While i'm here, anyone used rochester injectors? fair few supra's run em for E85 and they are fairly cheap but will need a custom rail + plugs for my setup.
saw these the other day as well, wondering how safe they would be.. keen to throw something like it in the honda though I've been advised it could run lean
http://www.ebay.com.au/itm/E85-Conversion-kit-Ethanol-Bioethanol-fuel-SAAB-VOLVO-FORD-VW-BMW-MERCEDES-OPEL-/320898056038?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab703bf66
Most ecu's will learn quite well considering, especially the newer ones. Of course it's always better to run an EMU or similar but in an NA engine it won't do any harm. Latency shouldn't be an issue with the newer design injectors imo. Do it Artz and prove me right. lol.
The other option is to run a new Walbro 416 or similar and bump up the pressure on the stock injectors.
ok looked into it a bit..cant easily run a reg cause its a non-return fuel system..I Know the honda ecu is pretty tricky, runs dual widebands and has lot of self learning features whether or not this will work in my favour or against im not sure...Apparently they get upset when cats are removed :unsure:
the thread i read where a guy just filled up with e85, said it was running 18:1 afrs...oddly enough it lost power on dyno but was faster than other cars the same...
Returnless fuel systems still have a reg in the tank normally. The self learning should be fine if you keep everything stock.
If you were planning to gain power don't bother. (unless you strap a turbo to it or bump the compression up to 15:1)
I probably wont bother anyway but it keeps me ammused thinking about it..:D
A nice bonus today when I went to fill up at United, they have decided to lower the price of e85 to 25c less than unleaded. (from 10c less) I ended up paying 96c a litre, it hasn't been that cheap ever as far as I remember...
Apparently United buying the ethanol processing plant in Queensland has filtered down to us plebs at the pump for a nice discount. :)
Serious? :woot:
Oh wait, i shouldnt get that excited as there is still only Caltex around here.... E70 it is.... I REALLY hope the E85 comes down in price so the popularity goes up so more stations are available...
There are 4 United servo's in NSW now, hopefully more will follow as they are pumping the Melbourne rollout heavily. Dont look if you don't want to get upset. lol.
http://www.unitedpetroleum.com.au/store-locator/fuels/E85
  • Like 1
http://www.unitedpet...cator/fuels/E85
Damn!
What is the current E content of the United stuff? How does it compare to E-flex?
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
