Running an old Wolf V4 that struggles a bit to get the tune refined.
Using 550cc RX7 injectors now but will run 910 siemens injectors if I switch to E85.
Obviously the bigger injectors will struggle more to find a good tune, but has anyone here tried tuning big injectors on a fairly old school ecu with E85? is it a harder fuel to tune or will it be easier due to the fact that it requires more fuel for the same power levels?
Will injector quality help this?
Don't wanna build a big fuel system with the works, get it to the dyno and find the ECU is just struggling overtime.
I don't think you would have an issue if you went with Bosch ev14's, not sure about the Siemens.
I recommend the Xspurt 1000's for e85 use, even ID's have apparently had issues with e85 coagulating to jelly, I suspect after mixing with the flow test fluid they use, and warranty returns to the US can be pointless. Guys, make sure you run ID's on petrol first.
yes but NOW they have a released an injector that is alcohol friendly.. :rolleyes:
you notice how it is exactly 30% bigger than there old ones :rofl:
ID725, 850, 1000 compatible with all known fuels. Compatible does not mean they aren't susceptible to problems caused by ethanol's love for gobbling up water, IF you abuse the injectors by letting ethanol sit in your tank for months they will die, this is common sense. ID1300 being stainless internals will have better resistance to corrosion IF there is water in the fuel. This is more likely in a race car that sees no action between meetings, with the older IDs you should pickle the engine by running it on petrol but with the ID1300 this is less important. In a road car seeing regular use I'm not seeing a massive advantage for the 1300's, heaps of people running 1000's + E85 without failures.
Yes I think the same of the stainless 1300s and if demand is there they may do the short 850 GMs and 1000s as well .
I can see where 1000s could be limiting on a 4 cylinder but 6s get an easier time with similar power outputs .
It's logical that a good injector sized properly will make the best of a more basic computer .
A .
Yeah would be nice, I ummed and aaahhed about the 1300's but they are quite a bit more expensive and at low pulsewidths they have a bit of ugly non-linearity. Totally doesn't matter for race cars, but I tend to think for road cars they might not be quite as well mannered as the regular offerings. I just ordered a set of short ID850-GM for my car so it fits under the inlet manifold more easily. Since my power goal is only around 250rwkw and it's a daily, 850cc is plenty. I'm not sure how frequently I'll run ethanol, it comes down to cost. I would like to run it regularly but time will tell.
Stao is making over 400rwkw using 800cc injectors and E85. That's plenty :P I couldn't afford new tyres at the rate 400rwkw would blow through them!
Definitely keen on running E85.. :) should be fun. I wouldn't run 91 octane in a fit, I guess what I said came across as cheap.. if I can get a good E85 tune then I will probably run it more.
Already posted in the hypergear thread and they said just go for it.
But I was wondering if anyone here knows how much power on E85 HKS 555 injectors could make.
Been running them in on my 98 tune for the past year making 250rwkw.
Thinking about going E85 but don't want to fork out for new injectors again.
E85 uses approx 30% more fuel than PULP. If you can multiply your current tune's duty cycle by 1.30 then you will get your new duty cycle (near enough), as long as that's less than 85% you're good to go.
A mate has an R33 with Nismo 555's and is making 240rwkw at about 45% duty. So there is heaps of headroom to run E85 on the same setup.
I keep telling people to go the 1000's but they insist on buying 5-600's, then complain when they max out. Just buy them and sell the 555's to some other sucker. :P
That adds extra money to my plans scotty :(
I'm not made of money dude!
Can you move to Canberra so I can have you do all my welding etc
Clutch will max out at 300 anyways.
So only wanted to get about 280-285
My gearbox has been out 3 times already so I'm not too keen to go down the slippery slope of upgrade after upgrade
Haha okay you talked me into it scotty!! fark!
I'm crashing at your place if I get kicked out for not paying rent.
Also now you have to help me with what highflowing E85 injectors I should be getting to fit in my stock rail.
Don't go telling me to purchase a new rail as well haha
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
