lutch will max out at 300 anyways.
So only wanted to get about 280-285
My gearbox has been out 3 times already so I'm not too keen to go down the slippery slope of upgrade after upgrade
You don't need to upgrade injectors for that power goal.
scotty seems to think everyone wants over 9000 killer wasps
  • 1 month later...
  • 2 months later...
Washable stainless filters are not fine enough, the dreaded black gunk seems fine enough to get through them and clog the injectors. I was recommended to install 10 micron paper elements to guarantee it would catch the black crap present in e85. (I assume from the manufacture of the fuel.) Moran refuse to warrant their injectors without a similar filter fitted in the fuel line...
E85 is a great cleaning solution and should flush any varnish buildup through, but this can block the filter internal to the injector, which in the EV14's is nearly impossible to clean.
wait, what? gunk in E85 from the manufacturer? (I thought it might happen if petrol stations filled ULP tanks with E85 without cleaning the tank first).
Is this a common problem or isolated?
Common, it builds up over time and circulates your fuel system, building up in the injector filter eventually. (Which is deep inside the injector on the ev14's.) For some reason my fuel system has been fine for years, but I have replaced 3 sets of ID's for customers due to this black crap recently.
I have a feeling it is from the carbon filtering of the ethanol during production. It does look a lot like carbon silt.
Currently running my rb20 on e85. Using a bosch 040 intank pump, all lines are speedflow series 200 hose (teflon), with tomei fuel reg, aeroflow inline fuel filter, standard fuel rail, and 565cc hks injectors. Making 266kw/357 hp, and mine doesn't chew through fuel like that at all.. Dyno graph in the rb20 dyno result thread
  • 3 weeks later...
Nah easy. I just carry a laptop with a 98 tune on it in case I have to stop for 98. It never fusses over a few litres of E85 left in the tank, and vice versa.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
