No, it comes down to pump fuel being horribly inconsistent and me not wanting to risk blowing up an engine because of one bad batch of fuel.
It's pretty simple to understand.
Horribly inconsistent.. If anything E85 should be quite consistent considering how it is contained at the servo unlike regular ULP and PULP.
There are others running around with 500rwkw (rb30's) without problems and not popping motors. Or is that an rb25 thing? :banana:
There are others running around with 500rwkw (rb30's) without problems and not popping motors. Or is that an rb25 thing? :D
There's a reason the market for Ethanol content testers has exploded in the states and it's not because it's the most reliably consistent fuel.
Let me put it another way:
If you tune an engine on the ragged edge, would you prefer to use a fuel with 0% difference between batches or 1% difference?
True.. However I think you worry too much given your fairly mild setup. :D
Unless that is you are throwing a GT42 or T51r and aiming for big numbers.
The GT35r 1.06. E85 or race fuel with good cams (265-272dur 10.5mm lift) your looking at ~420rwkw (behind a manual) on 20-22psi or so.
Your biggest problem are the cams when trying to make good power 350rwkw+ on reasonable boost levels.
Regardless you should be able to max out the turbo and able to 'easily' crack MTBT due to the GT35's large hot side on both E85 and race fuel. The tune WONT be ragged edge unless you try that on PUMP.
Any 'slight variation' in RON will not matter as you will be far away from the det threshold.
PULP is a completely different ball game as you won't get anywhere near MTBT so any slight variance in quality will have it knocking.
My ONLY concern with E85 is the blend variation between summer and winter.
Why would you tune any engine on the ragged edge unless your a fool with lots of money.
True.. However I think you worry too much given your fairly mild setup. :/
Nothing wrong with aiming for big (mph) numbers with a 25 and GT35/1.06 combo. The engine combo was spec'd as an example of what can be achieved with a very, very common setup that people can relate to. Not a GT47-equipped dyno queen.
Power figures only concern me to the extent that they're reflected by terminal speeds. My 5-speed stocker made 265kW on the bottle and ran 120mph @ 3240lbs race weight. Why could so many other similar cars only manage 114-116mph with 300kW? The point here is that I'd be happy for the dyno to show 150kW if it ran 140mph! :laugh:
I'm not concerned with breaking records on PULP. If I was, I wouldn't have stopped tuning at 19psi and 11.xx:1 AFR's.
I've highlighted the word that best describes my argument.
Regardless.
I'm not talking of comparing dyno figures/ET's or breaking records on pulp. :/
Simply pointing out where you may wish to improve if you want to squeeze every little bit out of that turbo.
Those cams are the down fall of the setup its as simple as that.
GT35r is a push over for E85. There is head room for a little variation due to MTBT (minimum timing best torque). I.e push more ignition in you make less power.
The summer/winter variation isn't too much of a hassle and will no doubt be sorted soon as summer approaches. Well at least on the dyno I run on as various track only cars have been setup for use with E85. I'll be sure to share the findings if the variation is an issue.
Regardless.
What cams are you referring to? The Poncams in my thing? The dyno seems to show that it's flowing well enough in all the right places. We'll see. The biggest problem I can see is that in my area, there's only one E85 servo and it's not what you might call busy or reputable. lol.
Interested in the fuel variation you see on the dyno.
Thanks for that.
The ragged edge is suicidal....! especialy with normal fuel's
With E85 it loses power before it detonates, so if your running on the edge with e85 you have a tune that is soooo far off from making max torque and power its not funny.
Say i would make max power at 25deg, i could turn it up to 35 and just lose power and torque with no detonation with e85 (this has not been tested but I am guessing for an example) :/
Yeah the poncams. 256 8.5mm lift.
Obviously you want every little kw out of the setup possible (your ragged tune comment) so bigger lift cams are a way of doing this while improving 'reliability' and reducing the RON requirement of your fuel.
You may then feel happier within yourself running E85 and saving hundreds of $$ per tank as its not so 'highly strung'.
All though E85 is perfectly fine due to the huge amount of head room (MTBT) it provides.
My 5-speed stocker made 265kW on the bottle and ran 120mph @ 3240lbs race weight. Why could so many other similar cars only manage 114-116mph with 300kW? The point here is that I'd be happy for the dyno to show 150kW if it ran 140mph! :)
From what I've seen, 120mph with 260-270rwkw is right on the money. My numbers below were achieved at that power level.
Not disputing that for a second. It's just people get so caught up with dyno figures it blows me away.
Found this link while doing some more research. Okay, I'll admit it, you guys planted enough of a seed to start my brain racing. Bastards!!
Aussie Ethanol
They list the Barrack Heights Ethanol service station as selling the stuff too. And the best bit? It's 2 mins drive from my house.
You bastards!
That is all.
You bastards.
Waiting for the final word from my tuner but yes, it's looking that way. I think the thing that sealed the deal was the servo so close to me and the fact that I'll give it a go, decide if it's worth the farting around and then go from there.
Adelaide had a shortage of E85 for a few weeks and i had to use varied blends of premium mixed with E85 and i was suprised how little E85 was needed to prevent knocking!! so i wouldnt stress too much if it's not 100% consistant, only downside i could see was a higher consumption!
Edited by 180or200
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
