I am willing to bet that a stock RB25 bottom end will be able to handle 350rwkw with E85.
Get me a stock rb25 engine and i will drop it into my car. If i break it at anything under 350 rwkw i will pay for the engine.
This fuel is soo forgiving its not funny. You can get the MAX torque level and then advance the timing a extra 10 deg and it will STILL NOT DETONATE.
DETONATION destroys engines!!! if your not pinging your RB25 it will last shitloads longer!!! Look at old mate from wollongong who ran over 380rkw and ran a 10 sec quarter on unstable pump 98...
add e85 to the equasion and your talking BIG power. I would not be suprised if you can reach 400rwkw with e85 and a stock RB25. (maybe some rod bolts might be needed but you never know lets try it ???)
dont listen to him Dave...its his birthday and he's drunk.
he's already rang and asked can he use your new engine as a test mule :(
lol
It will be a test mule, But ill be the one riding it. :(
My thoughts precisely Guilt Toy, I think its hard for people to get their head around how good this fuel actually is in making power and looking after the engine. Two extremely good things to have if you ask me.
strap a turbo to mine and chuck some injectors in there and you can use mine :( I barely drive it as it is...
Just make sure you keep Glue or sticky tape handy wont ya for those pistons :(
BINGO!
Im going to squeeze every usable (safe) power i can with my E85 setup.
Maybe 340rwkw.
Looking at your build i would say its very possible indeed. You have the larger rear and cams so should be up there thats for sure.
I still think my car has more in it also because boost goes to 24 and then trails off to 19 by redline. If i can get it to hold 22-23 to redline who knows. The day it was dynod wasnt the optimum either.
1st run it spun its lips off to the tune of 279rwkw so we re strapped
2nd run it wheel spun again at the top of the torque and registered 323.8
3rd run the heat had set in from idling and the runs before, it still spun a bit at the top of the torque but it was the only usable graph at 323.2
The torque line is so steep a ramp its almost unbelieveable hence the spinning on the rollers. Good times :(
Just make sure you keep Glue or sticky tape handy wont ya for those pistons :)
haha, i have cable ties in the car at all times! :laugh:
I'd be fine with it breaking, the battery got down to 9.1 volts just yesterday, I haven't driven it in weeks... I also found out that 9.2 volts is the bare minimum you need for HIDs to work :(
Im currently doing lots of research into reflux stills to make my own ! As it will be years until its up north QLD.
Reality is until lots of cars are E85 capable, it won't be prolific. I believe holden commodore is E85 in 2010 ???? This will be the catalyst i think , when the local cars can run it ..... can't wait.
Gary
i'm just waiting on my car to get back from the panel beaters and i'm good to go!
united are rolling out e85 at lots of servo's in vic real soon AFAIK
300rwkw on hks 2835 here i come!
You only have the .63 rear housing?
Jeez your power figure is impressive then, that would have to be the limit of flow for that turbo.
Might give 2bar a try, my new engine setup has slightly bigger cams and lower CR than the previous one so its a little more boost friendly.
HAPPY BIRTHDAY ANTHONY aka MAD SCIENTIST as Paul says :P
hi
long time reader, first time poster
did i miss something? i recall reading that guily toy tried 85 and it was poo
economy was horrible and it wasnt suitable - now all of a sudden its the best thing ever
what changed?
what needs to be done to the car to make it run on e85 properly
whats fuel economy like
hi
what changed?
it was... but then he tuned it some more and fell in love...
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
