Yeah still blows me away....You wont be dissapointed thats for sure
What really blows me away is it's making that power on 'mere' Nismo 555cc injectors and standard fuel pressure (OEM reg still fitted) Absolutely crazy results!
not to mention a std air box
his injectors are maxed out tho, he should think about an upgrade, i suggested sard 850's would give some nice headroom,
my 740's have a little more left in them but it suprises me how similar the settings are between the 555's and the 740's, I wonder if there really that different??????
posted in the wrong thread...
now editing with random letters as i have nothing constructive to add..
kdgf;IKGHDSLGNLdgFL;HGvugn'fug RPOTUGP'roug
fopgur
y ur
pyby
urebnp
YUEFRPYOUNBYUPYOU
yu
EYU
nryu
anyone want to answer my questions on the last page :D
really interested thanks
Well my guess is nothing else. In fact -standard turbo you might not even need injectors - give it a try and see how far your standard injectors are pushed.
im limited in terms of ecu's because my car is auto, getting a remap to run on 98 for the moment, so would i be able to do another remap to run the e85 or would i need a standalone computer to get it perfect, i.e fuel economy and reliability
also, wat if i mixed 10% e85 with 90% 98Ron, would i need a tune, ?
thanks
you will need to get a remap every time you change fuels...
so if you intend to keep changing around as i do then you will need an ecu
kool thanks, il jst save for a standalone computer that can run an auto car and other mods, until e85 is more readily available
Yeah i hear what your saying there Ad, a bit of headroom would be nice.
finally fitted my new pump and injectors. did some initial street tuning tonight, so far so good. duty cycle at 50% on 18psi so lots of scope for more boost and timing. hope to put it on the dyno in the next couple of days. i'll put up the dyno sheet asap.
Hey guys,
I keep reading this thread and it gets me thinking!!! UhOh!!
so since my engine is in the shop at the moment (RB26)
i was considering having the compression bumped up a bit to make the best use of this fuel..
Currently i am going to use 86.5mm Mahle Pistons c/r 8.5
what would be an ideal ratio for a dual setup perhaps just bump it up a little??? i'll run 98 and e85 (can store multiple maps..)
Cheers
Also
e85 locations in Sydney? i'm in Bankstown area.. google is crap for finding this stuff.. just finds a bunch of hippies raving on about sugar
Edited by Angus Smart
Here are the ones I know of:
E85 based on Manildra ethanol :
Shoalhaven Ethanol Fuel
215 Kinghorne St
Nowra NSW 2540
Ethanol Fuel
(near McDonald's) 251 Princes Highway
Albion Park NSW 2527
Ethanol Fuel
2 Rawson St
Granville 2142
Ethanol Fuel
987 Hume Highway
Lansdowne 2163
Foristville Ethanol
Warringah Road just north of the Coles Express Station. (to be verified)
E85 based on CSR ethanol
United Service Station
127 Victoria Rd
Rozelle NSW Sydney
I am trying to keep my Facebook Group as up to date as possible with the stations selling E85 check it out (link in signature)
If anyone can give me any more than that I will add them to the group details
Cheers,
Dan
e85 is back in the toy, ohhh man i love this shit. Getting the car tuned back to e85 was suprisingly easy with the vipec, seriously took 30 seconds with the software at the servo and we were on our way.
i was kinda annoyed because i got Dr Doof to come out with me to drive the car while i re-tuned it on e85, once i changed a few settings everything was running normal because the Closed Loop & Open Loop lambda correction became alive and is working 100% - better then it did on 98 for some reason?
so 30 second change over with just a couple of flat spots that needed taking care of.
Vipec suprised me again last night. what a ecu... :)
You and Doof are spending a lot of time together lately :)
Can one of you guys tell me what compression ratio would be ideal for a dual setup.
i have mahle's 8.5:1 going in at the moment. obviously i cant drop too much valves and the likes will hit? (i have no idea)
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
