Can one of you guys tell me what compression ratio would be ideal for a dual setup.
i have mahle's 8.5:1 going in at the moment. obviously i cant drop too much valves and the likes will hit? (i have no idea)
8.7:1 will live happily on both although the closer you can get to 9 without pistons and valves shaking hands the better for E85.
Power fc is for panzys!
Power fc's are still good.. they are just for Noobs who don't know or don't care to know any better.
I think a 9.5 compression ratio would be good for a dual setup. use 98 for street stuff then take e85 to the track.
Vipec are very good from what i have read, its many years the PFC junior which is alot in technolgy terms. Would be dissapointing if it wasnt a decent leap forward. That being said i'm more than happy with my pfc and dont see the point in spending the extra coin in upgrading.
Fair enough. I just set the closed loop lambda settings to be a bit more agressive with e85... wonder how this will work :)
Sell your Power FC while its still worth something.
I just had a conversation with a guy who has a Power FC, brand new Z32's and a E boost2.
sell Power FC and H/C = $1000 Z32's = $500 EBoost 2 = $500
thats $2000 - $1650 for Vi-PEC = $350 towards tuning. Guilt-Toy tune = $600 so he can get a better ecu and a better tune for $250...money well spent.
People spend $1000+ on cams that do nothing on some engines so $250 is peanuts.
Yeah I have to admit, after last night, I was pretty damn impressed! :D Anthony was a little pissed, it seems all I was there for in the end was to punish his clutch and thrash his car :)
All I need is some ricey read out display that doesn't require a car PC and I'm hooked :)
*plays the waiting game*
we are working on it...should be ready next month (feb)
Anthony, you should think about setting up a toggle switch so you can switch betwen fuel and ignition maps to suit. :) so its just a flick of the switch and you are on either E85 or 98.
i volunteer Paul to wire it up to DI5 or DI6 for you :D
Edited by TiTAN
Or keep it as its only 10 months old and i'm very happy with it...I'm making 330ish rwkw now on E85 with a PFC what more could you ask for, not much in my opinion.
oi Mr Dirt.. This is the E85 thread.. as much as i agree with you on the subject this thread is linked on heaps of forums world wide and i am sure they don't want to see our ECU Tuner wars battles
anti lag works good, i don't use it on the street though. i just have cycle idle on because when i use the air con the water temps go up to around 100deg, when i turn cycle idle on it cools it down and runs at about 94ish in traffic.
GT: Why are you getting such high temps in traffic with air con on?
Limping along slowly with air con on, the standard cooling system should be more then capable of containing the water temps... Is your hydraulic fan on the way out or something?
I know you have everything like air con condensor/FMIC etc in the way of the radiator, have you thought about setting up a "divider" to make sure the air that comes in the front bar HAS to go through the FMIC, radiator, etc?
my setup needs some attention. I am running the stock mspec front bar and have not chopped out the reo bar because i like my car to be legal.
The oil cooler is mounted on the front of the air con condensor, so its heating up there, i added a air con thermo fan and have replaced the clutch in the engine fan.
Its just that the radiator cannot get enough air from the front. its a Mspec radiator as well.. I need to move the oil cooler and install another thermo fan i think.
yeah it does run a bit hot, like I said, your idle temp is about the highest my temp will read... but like I also said, our cars are a lot different and I don't have as much shit going on in the engine bay as you do :(
But I do have better airflow with the front bar and bonnet, and no oil cooler in the way wither...
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
