my setup needs some attention. I am running the stock mspec front bar and have not chopped out the reo bar because i like my car to be legal.
The oil cooler is mounted on the front of the air con condensor, so its heating up there, i added a air con thermo fan and have replaced the clutch in the engine fan.
Its just that the radiator cannot get enough air from the front. its a Mspec radiator as well.. I need to move the oil cooler and install another thermo fan i think.
Try fitting an alloy radiator and a Nismo thermo stat.
Sounds like i have a similar set-up to yours, but i have cut the reo :), and my temps are mainly stable at 64-68deg. The highest i have ever seen it was 86deg at a drift day.
PS: Bonnet vents help alot too ;)
Who did you get to fill in the missing bits around the inside edge of the bar openeing?
A plastic welder in East Keilor, VIC.
I think they have closed down since, but you should be able to find one in the yellow pages.
im keen to give it a go on the track, will c the EPA about it considdering the fact that i have no cat... ill need to do some mods before she is finished however will need a good tuner. Guilt-Toy seems to have his head screwed on with loktite lol might see him about it....
Sounds like i have a similar set-up to yours, but i have cut the reo :banana:, and my temps are mainly stable at 64-68deg. The highest i have ever seen it was 86deg at a drift day.
PS: Bonnet vents help alot too :)
nice setup! i do have a alloy radiator, its a mspec one. my temps are okay on a 40deg day when my air con is off, as soon as i turn the air con on the temps go through the roof... got up to 102deg today (cycle idle was off)
I got a new genuine nissan thermostat as well.
My oil cooler is on the other side so my fan is where your oil cooler is.
are you running a rediator shroud? I broke mine and havent been able to find one recently and I find my temps sit around 86' compared with 81' when I first fitted the ally radiator with shroud
Hey Al have you got more pics of your car somewhere its on f*kin clean gtst!
yes i i do have the shroud.. seems my car runs a bit hotter for some reason... might try some better coolant or move the oil cooler? my oil cooler is heaps bigger then that one on Als car
not to mention a std air box
his injectors are maxed out tho, he should think about an upgrade, i suggested sard 850's would give some nice headroom.
Just an update for those interested, i have noticed this thread has been a bit quiet of late.
I have sold the 555's and in the process of purchasing SARD 850's (should receive mid next week).
Also purchasing 24psi actuator off a fellow member which i should recieve early next week also.
POD filter has just been bolted back on.
Be interesting to see how it goes holding the 24psi boost with plenty of fuel and air. Adrian will be tuning again (your a legend mate whats this make it 5 or so now). If it feels noticeably different it will getting run up on the same dyno again. If not it can wait til next months dyno comp.
I'll add my 2c too.
We finally fired up my RB25DET at the end of last week using 910cc inj' and running E85 for the first time.
Scaling ~25% fuel out of the map for the old 550's saw it start up and purr away like a kitten.
And now that the Adelaide temp's have dropped from 'insanely hot' to mid 20's I'm expecting a dyno number sometime next week. Still have to do a bit of tidying up after the rail and injector change, but it all looks neat enough.
:) Ha-ha. He's a man with a memory like an elephant. I was considering upgrading the cement to top quality 300*300*40 pavers, as not only do they give a nicer Autosalon style boot display, but they also allow more adjustment in weight distribution :)
GT: May I suggest attempting to swap your radiator for a stock Koyo one?
Have seen issues from Alloy rads not dispersing heat properly.
Either that, or chuck a volt meter in the coolant whilst engine is running, and against battery earth... Do not let the probe in the water touch metal of radiator.
Then do a test from rad itself to battery neg...
If you get a voltage usually about like 0.5Volts on either, throw an earth strap on the rad.
you mean a stock nissan one? i do have a spare actually.. and as for the earth, i already have a earth strap on it.. put that on a couple of weeks after i got the alloy radiator...
I am getting one of those swirl pots, to go on the cooling system. when i turn the car off i can hear bubbling in my coolant system.. just noticed it.. maybe the top mount turbo is causing air in the line and causing the extra heat?
is it bad to run the engine at 100deg? or 97?
Brief stints at those temp's are nothing to be majorly concerned about, but if it's a regular occurrence I'd be looking at rectifying the situation, GT.
It's not something simple like a dud radiator cap is it - I know it's one of the first checks you would do, but I thought I'd ask.
Bubbling is also an indicator of head gasket or head problems which would also cause it to run hot.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
