There are no ecu options for the M35 Stagea's yet, i'm running an Emanage ultimate and switching a second map for the e85 with the front panel dip switches. Cold plugs too, probably some of the reason i'm having issues with cold starts. Anything below 15 degrees and she wont fire.
I have to put 10% extra premium in the tank at the moment or it doesn't start. As the throttle is electronic, I cant gas it to dump some fuel. Once its running, no problem.
Next mod will be a small petrol canister in the engine bay, with a pump and injector powered from a switch on the dash. That should solve it. :)
There aren't many plug options (no cheap copper plugs available) but I would rather the colder ones for now, from what I have researched they will still give a better burn once the engine is warm and I won't sacrifice performance for a simple cold start issue. A petrol primer button in the dash seems like a better option for winter as it only needs a teaspoon to fire, I have all the parts to make it, and I don't have to pay to retune and rewire the emanage.
Is anyone else had any issues with the cold mornings lately? I understand you can just stab the pedal and dump a bit of fuel but what happens if you don't?
Mmm, my issue is with the actual cranking, once it has started (first 10 seconds) all is good, although you are right, a bit sluggish until you get some warmth into it.
The amount of steam coming out the back on a cold morning start is amazing...
there is sugarcane ethanol and wheatgrain ethanol
i find the wheatgrain to be a better product. both fuels reached the same kw, same tuner same dyno, but the wheatgrain used 2 deg less timing
then some barrel e85 is blended with 98 while pump e85 is blended with 91
Its been re-filled. I wonder if fresh ethanol goes any better like premium... :bunny:
Joey, why didn't you just take a jerry or two up with you? I got great economy on a run down to PI track for the classic meet. I'm not giving up all that killer midrange.
  • 1 month later...
Good to see!
I forgot to mention the possible variance in my comment, though hopefully E85 comes as 85% +/- 1% max.
Seeing as my car is being fitted with new turbo, Nismo 740's (overkill for 280rwkw in prep for this wonderful elixir), and the ViPEC, I hope to be one of the first in Canberra to be running this from the pump!
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
