Going to have a crack at getting a 204L drum of powerplus e85 when I get back from overseas and run a 50/50 mix with BP98... (I'm tipping about a 15% rise is fuel requirements?!?)
Should be interesting to see how the results go on a RB20 with decent boost!
unless you can do that on the fly, you'd have to have a map for E70 to cover all bases.
Yeah thats what I was thinking youd have to have a 70 map and 85 one which is to much of a hassle and will the blends be random just by luck what you get or you know when your geting what.
E70 would help with cold starting anyway. Here are the locations, none near me of course.
http://www.caltex.com.au/ProductsAndServic...s/BioFuels.aspx
Hopefully more fuel companies will jump on the band wagon, they would be stupid not to.
what about running a permanant wideband AFR gauge and tuning the AFR's to suit e70, e75, e81.2 ect ect?
maybe leave the timing a bit retarded for e70 right through to e85, but tune the AFR's to suit each tank?
Probably more time and $$ than it's worth.
Would end up being easier to mix your own fuel in bulk at home or something...
Would anyone expect the cost of Ethanol to come down when this goes ahead? It will be more widely produced, so procuring E100 would be easier in theory....this would make mixing your own CONTROL fuel at home cheaper.
The fueltown in Melb that sell Powerplus Ethanol, do mix their own. So if you really wanted, you could get E100 from them at the servo (as some of their race customers do)
E85 is yesterday news, come on E100! :D:)
Ethanol will be going up in price as it stands at the moment. The fuel excise will increase it to $1.20L in the next year or two from what I have read.
Caltex have stated it will be significantly cheaper than unleaded which is $1.18 here at the moment so I cant see it selling for more than $1.
E100 is definitely the go, but cant legally be sold can it? I have seen a car running it from drums but realistically I cant be getting a drum delivered every week... Im stuck running what comes out of the nozzle.
speak to the guy down at Fueltown scotty - i reckon he'll let you fill up with E100 if you want. Granted, not out of the pump, but i'm sure something can be arranged :ermm:
Maybe do the car and 2 jerry's, and keep the jerry's at home.
I filled there last night, 160L (car and 4 jerries) the attendant said I have a huge fuel tank. LOL
When I get home I have a 44 out the back I tip the jerries into which I use to fill the car, 20psi air pressurises the drum and a servo nozzle to fill it automatically so I am well set up for E100 if I could get it home.
I will speak to him next time im down there during the day...
dude.... results MUST be shared if you get an E100 tune!!! :ermm::( :( :banana:
i thought i was crazy driving to Hoppers back in the day (50mins one way) to get a tank, plus 2 x 20L jerry's.... you've certainly taken it to another level! love your work! :D
How much better will the e100 do though, bugger all I would say. I will be looking into it, what's another map when you have 20 on the laptop already. :ermm:
With known mapping for E70, 85 and 100 I could automate it with the ethanol content sensor and set up a secondary (4th?) map on the Emanage to adjust, as long as the sensor is reliable... Not having to worry about what fuel I put in would be great. Im sure there will be units that do this coming out of the aftermarket industry as soon as there is infrastructure in place.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
