Guilt-toy Now Running On E85 !
I'm very much limited to what NIStune can do.
Other than the fact that I would have had a bit more stuffing around to sort nistune on a 33, this is why I spent the bigger dollarz and went with the ViPEC :)
OK so since it looks like nobody want to buy my rims lol, I'll probably get myself new a new CAT of some description, and a wideband from wbo2 in the coming months....
and some ku36's, coz these Maxxis tyres SUCK with power.
sorry if this has been covered earlier, my wideband doesnt read in lambda so im stuck with the gasoline calibrated AFR's.
what ive read is you divide your GAS AFR by 1.5 to get your actual AFR on E85.
it looks like the AFR's on your GAS calibrated AFR dont change too much, ive ripped a table from: http://www.e85forum.com/ntopic777.html&amp...721aef0b42b578a
Idle/Cruise = 14.7 - 15.2
Light Load = 12.5 - 13.2
Pre-WOT load = 11.5
WOT = 11:1 - 10.5
these figures are for gasoline calibrated AFR's.
does this sound right to the pro's?
update on my E-Flex adventures.
Car feels AMAZING to drive, more torquey, smoother throughout the entire rev range.
290rwkw with siemens deka 550cc injectors, walbro pump. still more left in the injectors, and pump seems to be keeping up just fine.
i ran a walbro the whole time i was on E85, 740cc injectors - never any issues, prob about 18months straight of exclusive E85 use - bout the same power as well
Your opinion is invalid as you have shown mental instability when you sold that absolutely amazing R34 of yours. Shame on you.
lol :blink:
Oh I didnt realise that result was on E85! Did you have a tune on 98 as well?
He only ever got his 98 tune results once I believe, and it was with a really restrictive intake so it only made 266rwkw when the piping was killing airflow.
This tune was on E-something....like E70 or thereabouts
Here's a quick excel of my pre and post caltex e flex fuel :blush:
NOTE!!! the Caltex E-Flex was actually run with LESS boost
PULP 98 spiked up to 21psi then dropped to 15 and held
Caltex E-Flex spiked to 19psi then dropped to just under 14psi by redline (where peak power was made)
I used the formula ((Speed/28)*1000) for the revs. Not exact but very close
almost 50rwkw gain through the midrange and this is only e70 at the moment...
giggity!
Yeah Pat your results make me cry. LESS boost, and HUGE gains in midrange. Fark I gotta get up early to fix my cooler piping tomorrow, not driving my car hurts. Can't wait to make the switch as well, just gotta get a bloody wideband :blush:
fark.. you guys are still going with this :thumbsup:
I been in Abu Dhabi in UAE tuning, fuel here costs 50c a litre for 98 =) and money is never a problem for guys wanting to build cars...
how different is the Caltex stuff to the United stuff? With e85 i never had any starting issues, only difference was a extra 4 cranks of the engine and that was it.
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
